  1. DECEASED
    Jun 2009
    Heaven
    Originally Posted by racer-x View Post
    You can encode webp files with current version of ffmpeg. I tried to post one the other day, but this site doesn't allow those.
    I have added .webp attachment support.
    Hmmmmm......
  2. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    Your test picture is better than mine....
  3. Member racer-x's Avatar
    Mar 2003
    Dang, it doesn't display the image, only provides a link.
  4. DECEASED
    Jun 2009
    Heaven
    According to the Wikipedia entry:
    Amongst web browsers, Google Chrome and Opera natively support WebP. All WebM-compatible browsers can also display WebP via a JavaScript shim. WebP can also be displayed in all major browsers using the WebPJS JavaScript library, although support in Internet Explorer 6 and above is achieved using Flash)
    Looks like WebP is not so important as Google wants us all to believe
    For the curious, and FWIW as well: https://bugzilla.mozilla.org/show_bug.cgi?id=856375
    Image Attached Images
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    Test:
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    Vbulletin 4 doesn't support webp as images. You can post it and then use [img]-tags.
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    Test:
  8. Test via IMG tag
    via ATTACH tag
    Stopping development until someone save me from poverty or get me out of Hong Kong...
    Twitter @MaverickTse
