Hello,
I have created some DVD's and am wondering if I can change the way the DVD icon looks when loaded into a computer.
thanks
maybe you mean jacket_P
do a search....
Here is an old link I dug up in a search, maybe this is what you mean? https://forum.videohelp.com/threads/175984-How-to-Make-JACKET_P-PicturesGot my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
Or do you mean something like this? http://www.iconarchive.com/tag/dvd
Of course every PC will just show a default icon unless you change them. They are not part of the DVD itself.
And welcome to our forums.
Also, you CAN change them on the PC and Mac side, via Autorun [Icon] on PC (though it must be enabled, and that is far from universal, or even recommended anymore) and via Mac disc alias custom icons ( though that requires a bridge disc, created on the Mac side).
ScottLast edited by Cornucopia; 15th Dec 2014 at 00:53.
Before burning disk,
Create file = autorun.inf, example = "[autorun] icon=jeff.ico"
+ "jeff.ico" in root of disk.
Works with C:\ D, E, F, etc.
[Attachment 29143 - Click to enlarge]
"My Computer" here, but works with CD's, DVD's, Thumb drives, etc.
Is this what you mean?
Dont know how to burn with movie DVD's tho.
-c-Yes, no, maybe, I don't know, Can you repeat the question?
