Hi I'm trying to create selectable subtitles using submux. I use Sub station Alpha to create them, using MaestroSBT to convert to submux format and when I try to multiplex them with the video is when trouble starts. If I use the submux gui I click start and nothing happens and when I use it in the DOS prompt I get errors: "Unable to open file xxxxxx0001.bmp Bad Image, skipping line 1; Unable to open filexxxxxx0002.bmp Bad Image, skipping line 2..." and so on, and so on... I've tried using in Maestro other image formats like 4 bit, 8 bit, rgb, tga and nothing works. What is going on?
Results 1 to 1 of 1
Unable to run VobSub (SubResync or Submux)
By DeathStalker77 in forum SubtitleReplies: 1Last Post: 16th Sep 2009, 17:07 -
SubMux ~ DVDplayer problem
By Sir Liam in forum SubtitleReplies: 3Last Post: 17th Oct 2008, 07:10 -
Winsubmux error. Plus submux not muxing
By Codecoder in forum Authoring (VCD/SVCD)Replies: 1Last Post: 12th Jul 2008, 22:30 -
submux output avi file no sound on standalone DVD player
By sigmma in forum SubtitleReplies: 2Last Post: 24th May 2007, 05:19
