    Nov 2014
    The Czech Republic
    Hi guys,
    Do you know, which application could shift the timing of my French subtitles (only one version available on the whole of Internets) that work fine with a DVDrip of the movie so that they work for a BluRay version that I have?
    I heard somewhere it has to do with the framerate or something like this that can be meddled with to work fine
    The DVDrip:
    Format                                   : AVI
    Format/Info                              : Audio Video Interleave
    File size                                : 700 MiB
    Duration                                 : 1h 27mn
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 1 115 Kbps
    Writing application                      : Nandub v1.0rc2
    Writing library                          : Nandub build 1853/release
    Video
    Format                                   : MPEG-4 Visual
    Format profile                           : Advanced Simple@L5
    Format settings, BVOP                    : 2
    Format settings, QPel                    : No
    Format settings, GMC                     : No warppoints
    Format settings, Matrix                  : Default (H.263)
    Muxing mode                              : Packed bitstream
    Codec ID                                 : XVID
    Codec ID/Hint                            : XviD
    Duration                                 : 1h 27mn
    Bit rate                                 : 971 Kbps
    Width                                    : 576 pixels
    Height                                   : 304 pixels
    Display aspect ratio                     : 1.895
    Frame rate                               : 25.000 fps
    Bits/(Pixel*Frame)                       : 0.222
    Stream size                              : 610 MiB (87%)
    Writing library                          : XviD 1.2.1 (UTC 2008-12-04)
    Audio
    Format                                   : MPEG Audio
    Format version                           : Version 1
    Format profile                           : Layer 3
    Mode                                     : Joint stereo
    Mode extension                           : MS Stereo
    Codec ID                                 : 55
    Codec ID/Hint                            : MP3
    Duration                                 : 1h 27mn
    Bit rate mode                            : Variable
    Bit rate                                 : 128 Kbps
    Sampling rate                            : 48.0 KHz
    Stream size                              : 81.9 MiB (12%)
    Alignment                                : Aligned on interleaves
    Interleave, duration                     : 24 ms (0.60 video frame)
    Interleave, preload duration             : 135 ms
    Writing library                          : LAME3.90.
    Encoding settings                        : -m j -V 4 -q 2 -lowpass 17.6 --abr 128
    The BluRay version:
    Format                                   : Matroska
    Format version                           : Version 4 / Version 2
    File size                                : 6.05 GiB
    Duration                                 : 1h 31mn
    Overall bit rate                         : 9 463 Kbps
    Encoded date                             : UTC 2013-06-11 00:55:51
    Writing application                      : mkvmerge v6.2.0 ('Promised Land') built on Apr 28 2013 12:22:01
    Writing library                          : libebml v1.3.0 + libmatroska v1.4.0
    Video
    Format profile                           : High@L4.1
    Format settings, ReFrames                : 9 frames
    Codec ID                                 : V_MPEG4/ISO/AVC
    Duration                                 : 1h 31mn
    Bit rate                                 : 7 765 Kbps
    Width                                    : 1 280 pixels
    Height                                   : 694 pixels
    Display aspect ratio                     : 1.85:1
    Frame rate mode                          : Constant
    Frame rate                               : 23.976 fps
    Bits/(Pixel*Frame)                       : 0.365
    Stream size                              : 4.96 GiB (82%)
    Title                                    : Le Petit Nicolas (2009)
    Writing library                          : x264 core 133 r2334kMod a3ac64b
    Encoding settings                        : cabac=1 / ref=9 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=10 / psy=1 / fade_compensate=0.00 / psy_rd=1.05:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc=crf / mbtree=0 / crf=17.0000 / qcomp=0.80 / qpmin=0 / qpmax=51 / qpstep=4 / ip_ratio=1.30 / pb_ratio=1.20 / aq=1:0.80
    Language                                 : French
    Default                                  : Yes
    Forced                                   : No
    Audio
    Format                                   : DTS
    Format/Info                              : Digital Theater Systems
    Mode                                     : 16
    Format settings, Endianness              : Big
    Codec ID                                 : A_DTS
    Duration                                 : 1h 31mn
    Bit rate mode                            : Constant
    Bit rate                                 : 1 509 Kbps
    Channel(s)                               : 6 channels
    Channel positions                        : Front: L C R, Side: L R, LFE
    Bit depth                                : 24 bits
    Stream size                              : 988 MiB (16%)
    Language                                 : French
    Default                                  : Yes
    Forced                                   : No
    Text #1
    Format                                   : UTF-8
    Codec ID                                 : S_TEXT/UTF8
    Codec ID/Info                            : UTF-8 Plain Text
    Title                                    : Czech
    Language                                 : Czech
    Default                                  : No
    Forced                                   : No
    Text #2
    Format                                   : UTF-8
    Title                                    : English
    Language                                 : English
    Default                                  : No
    Forced                                   : No
    Text #3
    Format                                   : UTF-8
    Title                                    : French
    Language                                 : French
    Default                                  : No
    Forced                                   : No
    Text #4
    Format                                   : PGS
    Muxing mode                              : zlib
    Codec ID                                 : S_HDMV/PGS
    Codec ID/Info                            : The same subtitle format used on BDs/HD-DVDs
    Title                                    : French (PGS)
    Language                                 : French
    Default                                  : No
    Forced                                   : No
    Text #5
    Format                                   : UTF-8
    Title                                    : Greek
    Language                                 : Greek
    Default                                  : No
    Forced                                   : No
    Text #6
    Format                                   : UTF-8
    Title                                    : Vietnamese
    Language                                 : Vietnamese
    Default                                  : No
    Forced                                   : No
    Menu
    00:00:00.000                             : en:Chap. 1
    00:07:54.057                             : en:Chap. 2
    00:10:34.509                             : en:Chap. 3
    00:14:07.555                             : en:Chap. 4
    00:19:54.485                             : en:Chap. 5
    00:32:15.725                             : en:Chap. 6
    00:36:48.164                             : en:Chap. 7
    00:45:23.304                             : en:Chap. 8
    00:51:34.133                             : en:Chap. 9
    01:00:00.138                             : en:Chap. 10
    01:09:59.987                             : en:Chap. 11
    01:19:36.689                             : en:Chap. 12
    01:26:23.678                             : en:Chap. 13
    Thanks for help
  2. DECEASED
    Jun 2009
    Heaven
    That can be done easily with Subtitle Workshop.
    Set the Input FPS to 25, open the SRT file, set the final FPS to 23.976, save to a new file.
    Nov 2014
    The Czech Republic
    But it says they are unsopported format...
    Sep 2007
    Europe
    Subtitle Workshop doesn't support unicode.
    Load the srt in notepad or wordpad and save a copy as ANSI. Then follow the suggestions of El Heggunte.
    Nov 2014
    The Czech Republic
    Oh, stupid me It works now, thank you guys
