Hello gets,
I am using Tubedigger with good success. I downloaded some streamings and fixed them with Tubedigger. As result I have full functional file with audio/video sync. When I try to convert it to WMV or MPEG I get the video with no audio.
I have used Replay Video Converter from Applian.com and also WinX DVD converter. In both cases using the default parameters.
Can somebody help. I am pretty new to the field and I do not know much about it.
Kind Regards
Can you post the details from the mp4? Use mediainfoxp.
Or just try another converter like xmedia recode, video to video converter, format factory, etc. -
Dear Baldrick, thank you for replying.
I have attached the analysis result from videoxp
General
Complete name : C:\Users\Pierfrancesco\Videos\TubeDigger\rox.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 2.84 MiB
Duration : 41s 889ms
Overall bit rate : 569 Kbps
Writing application : Lavf54.63.104
Video
Format : AVC
Format profile : Main@L3.1
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=10
Codec ID : avc1
Duration : 24s 40ms
Bit rate : 899 Kbps
Width : 800 pixels
Height : 600 pixels
Display aspect ratio : 4:3
Frame rate mode : Variable
Frame rate : 30.000 fps
Minimum frame rate : 25.000 fps
Maximum frame rate : 30.001 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.062
Stream size : 2.57 MiB (91%)
Color range : Limited
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Bit rate mode : Variable
Bit rate : 48.0 Kbps
Maximum bit rate : 51.7 Kbps
Channel(s) : 2 channels
Sampling rate : 22.05 KHz
Compression mode : Lossy
Stream size : 254 KiB (9%)
I have installed video to video converter which seems quite user friendly.
The conversion process works except the fact that audio is no longer aligned with the video.
Do I have any simple tool that helps me to re-align video and audio timeline. Or any other tool that does that automatically?
Kind Regards.
