  1. The TS clip is cutted by 5 parts
    I use Smart Cutter (one of the best TS cutter/joiner as I know) to merge TS file
    but the transition isn't smooth !
    Can anyone teach me how to join the clips ?
    Here is first two parts of the clip
    https://mega.co.nz/#!u5YHUQTb!FraK7ycfXg79jz_o6qSyPpO53YzEjHfJnTVrmgaLYa8
    Thanks a lot
    [Solved]
    I tried used a basic file copy mode:
    copy /b "2013wc 1.ts"+"2013wc 2.ts" new.ts
    from the command prompt and the merge looks fine in vlc media player.
  3. Originally Posted by Baldrick View Post
    Hi Baldrick
    You mean
    1. open command promt
    2. type > copy / b “2013 WC 1.ts"+"2013 WC 2.ts" new. ts
    it will merge the ts clips ?
    Where the ts clips should be placed ?
    in C:/ ?
    Put the clips in for example c:\temp.
    In the command prompt type cd c:\temp and then the above copy example.
  5. Originally Posted by Baldrick View Post
    I know how to join the files
    Thanks for telling me this useful command
    Thanks Baldrick
    May 2009
    Europe
    Similar problem.
    Full HD recording done by DVB-T2 set-top box. The folder contains series of ts and dvr files, ts-files numbered 000.ts, 001.ts etc. However the merging of them seamlessly has been unsuccessful.
    Tried tsMuxeR, the result is not seamless for both video/audio and audio goes out of sync up to seconds. Changing audio delay may help in the beginning of the video, but not in the middle or in the end. Every individual ts file is however ok sync-wise.
    Also tried to merge the files using Command prompt described in this thread. The result is not seamless as well.
    The resulting video file should still be .ts, without recoding, with one added audio track.
    I'd appreciate any advice how to get better result.
    Mediainfo of the 000.ts just in case:
    General
    Complete name : 000.ts
    Format : MPEG-TS
    File size : 1.00 GiB
    Duration : 16mn 42s
    Overall bit rate : 8 570 Kbps
    Video
    Menu ID : 51 (0x33)
    Format : AVC
    Format profile : High@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 3 frames
    Format settings, GOP : M=4, N=32
    Codec ID : 27
    Duration : 16mn 42s
    Bit rate : 7 758 Kbps
    Maximum bit rate : 8 500 Kbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 25.000 fps
    Standard : Component
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Bits/(Pixel*Frame) : 0.150
    Stream size : 927 MiB (91%)
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio #1
    Menu ID : 51 (0x33)
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 2
    Codec ID : 4
    Duration : 16mn 42s
    Bit rate mode : Constant
    Bit rate : 256 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Delay relative to video : -551ms
    Stream size : 30.6 MiB (3%)
    May 2009
    Europe
    I'll try if you tried yourself and are satisfied with a result.
