  1. http://www.dailymotion.com/embed/video/k4kQh0TROpl9qH9zgir
    How can i download this one?
    In the past i used ffmpeg and livestremer but can't get them to work with this one.
    thanx
  2. Hi beo59 ,
    2 links :
    @echo on
    rem best
    ffmpeg -i "http://www.dailymotion.com/cdn/manifest/video/x2c6i3z.m3u8?auth=1418508115-2562-dzjonhp3-a472f8ede0f2bb5dd5e69fead8be835a" -vcodec copy -acodec copy -f mpegts flux_best.ts
    pause
    rem worst
    ffmpeg -i "http://www.dailymotion.com/cdn/H264-512x384/video/x2c6i3z.mp4?auth=1418508115-2562-amkwv0os-cd4d4fd9f11f68414109673a0d4715d5" -vcodec copy -acodec copy -f mpegts flux_worst.ts
    pause
    :end
    Cheers .
  3. Hi aazerty,
    thanks for the reply, but i still can't get it to work.
    C:\Users\root\Downloads\Compressed\ffmpeg-20141212-git-e07c826-win64-static\ffmp
    eg-20141212-git-e07c826-win64-static\bin>ffmpeg -i "http://www.dailymotion.com/cdn/manifest/vi
    ffmpeg version N-68390-ge07c826 Copyright (c) 2000-2014 the FFmpeg developers
      built on Dec 12 2014 00:41:08 with gcc 4.9.2 (GCC)
      configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enabl
    e-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --e
    nable-libbluray --enable-libbs2b --enable-libcaca --enable-libfreetype --enable-libgme --enabl
    e-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb -
    -enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libs
    chroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable
    -libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx -
    -enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enabl
    e-libxvid --enable-decklink --enable-zlib
      libavutil      54. 15.100 / 54. 15.100
      libavcodec     56. 14.100 / 56. 14.100
      libavformat    56. 15.104 / 56. 15.104
      libavdevice    56.  3.100 / 56.  3.100
      libavfilter     5.  3.100 /  5.  3.100
      libswscale      3.  1.101 /  3.  1.101
      libswresample   1.  1.100 /  1.  1.100
      libpostproc    53.  3.100 / 53.  3.100
    [http @ 0000000000344e80] HTTP error 403 Forbidden
    8ede0f2bb5dd5e69fead8be835a: Server returned 403 Forbidden (access denied)
    C:\Users\root\Downloads\Compressed\ffmpeg-20141212-git-e07c826-win64-static\ffmpeg-20141212-gi
    Did you extract the link with abp?
  4. Hi beo59 ,
    Maybe the problem with 'auth=...' .
    1st step : INSTALLING PHP
    Download 'php' at :
    http://www.mediafire.com/download/85a2dvag8a7o6io/php.rar
    EXTRACTING
    Right click on 'php.rar' ; 'Extract to' ;
    In 'Select to' write : 'C:\php' , and ok
    2nd Catching API
    DL the file
    http://darbycrash.altervista.org/PHP/api.php.txt
    rename it as 'api_662.php' , to be put in the same directory of 'php.exe' .
    3rd DL streams
    create a batch file ( 'daily.bat' ) , to be put in the same directory of 'php.exe' .
    @echo on
    php api_662.php http://www.dailymotion.com/embed/video/k4kQh0TROpl9qH9zgir
    pause
    :fin
    Launch 'daily.bat' after a moment you'll can stop ( after seing the below message )
    You'll get a file 'history.txt' ( in the directory where is staying 'php.exe' ) .
    In it you'll find 4 streams . To be tried in a newest batch file .
    Regards .
  5. Member Emeritus
    May 2014
    Originally Posted by beo59 View Post
    You can just download the file with your browser or a download manager by using the http link. Load the video page, view page source, search page source for:
    ,"stream_h264_hq_url":
    Search for the exact string above, including all punctuation.
    Following the above string is a url like the following, but remove all instances of "\" character:
    http://www.dailymotion.com/cdn/H264-848x480/video/x2c6i3z.mp4?auth=1418567057-2562-wpedlrfc-c6b30c68c551a905c04770cb6d8106a8
  6. Hi ,
    @ponens : it works . Thanks .
    The interest of the api.php is to catch links from 27 platforms .
    Regards .
