Page 2 of 2
FirstFirst 1 2
Results 31 to 40 of 40
  1. Here's my comparison of SmoothFPS2 (left) and MSU_FRC (right):
  2. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    This is not without limitations however. I did my own 3 picture faux 3-D pan and used SmoothFPS2(). Adjusting the Block Size helps one problem, but creates other problems. The best you can do is try to reach an acceptable compromise....
  3. Originally Posted by racer-x View Post
    In fact, it doesn't work well most of the time. I use motion interpolation very infrequently, usually to replace a single (or a few) bad frames, or insert a single (or few) missing frames, here and there. See ReplaceFramesMC() and InsertFramesMC():
    https://forum.videohelp.com/threads/352741-Frame-interpolation?p=2226119&viewfull=1#post2226119
  4. Some pervert in Japan made a similar tool that takes only one picture:
    Video demo(warning! slightly pervert/erotic):
    http://www.nicozon.net/watch/sm17550572
    Software DL:
    http://onjn.nomaki.jp/index.html#tikuwa
    (direct link) http://onjn.nomaki.jp/archive/tikuwa4.zip
    Stopping development until someone save me from poverty or get me out of Hong Kong...
    Twitter @MaverickTse
  5. Member racer-x's Avatar
    Mar 2003
    Looks interesting, but I can't download it. Can't you just post the zip file?
  6. google found this link
    http://ftp.vector.co.jp/pack/win95/art/anime/tikuwa4.zip
    I downloaded it, it's clean and looks legit, but no translation
  7. Yes, the program uses hand painted colors to apply depth cues then rotates the video in 3-space.
  8. Member racer-x's Avatar
    Mar 2003
    I cant get there through that link either, I just get redirected.......
  9. mirror
    It looks similar to AE's displacement mapping
