Results 1 to 10 of 10
  1. I will try to explain this as best I can. I run a large video wall and when I play a video on the video wall every image that has a very dark or black background has multicolored block in and around it. It moves with the image until the image moves away or out of the dark background. Is this mosquito noise? All inputs and outputs to the wall are DVI. I am using an ATI Firepro V8800 video card for the GPU.
    I have attached an image as an example.
    Any help would be greatly appreciated.
    Thank you
    Brian
  2. Banned
    Oct 2014
    Northern California
    Those are compression artifacts.
    Most likely the video was rendered too dark, compressed and then when the darks were boosted at view time those artifacts came to light.
  3. Did you try another video?
    Extraordinary claims require extraordinary evidence -Carl Sagan
  4. The same thing happens on other video's I have downloaded but not ones that are made in house. I am happy they are compression artifacts and not hardware failure. Is there a way to fix it?
    canada
    Only way to get a better video is to buy the discs,no way to fix compression artifacts.
  6. Thank you very much for your help. At least I know it is not me.
  7. Another question;
    We tried playing eve-online on the wall to test 3D images on the wall. This also showed compression artifacts. Are the compression artifacts also due to low quality video? Or can this be related to internet speeds?
  8. I'm a Super Moderator johns0's Avatar
    canada
    It's due to how the video was encoded with too low of a bitrate.
  9. I think you just blowing up those vids so much so that you can see all the faults like those artifacts. Try looking at it with a normal sized TV and I bet those artifacts go away. Low bitrate and low resolution will give you those bad results on your multi-screen wall.
  10. Great,
    Thank you again. And now the final question:
    Are there any courses I can take to help me better understand all of this? I found myself in charge of a 5X7 video wall and need to get better aquainted with the technological factors.
    Thank you
    Brian
