    Apr 2014
    ardabil, iran
    hi to every one
    i want to make test file for home theater systems and i want to make a 5.1 sound with 6 mono files.
  2. Member Cornucopia's Avatar
    Do you have the mono files already? What format are they? Are they all of the same type?
    Which "home theatre systems" are you talking about? - to test WHAT?
    More info needed.
    Apr 2014
    ardabil, iran
    thanks for your reply
    i dont have the mono files, but i can record them easily
    i can convert the into any desired format
    by home thearte, i mean 5.1 or 7.1 or any surround system to see if the channels of audio is really distinguished and transmitted to right speaker/
    my test will be a voice saying like: front left (for front left channel), front right(for front right channel) and etc.
  4. Member Cornucopia's Avatar
    No need to re-invent the wheel: just go to this site - http://www.jensign.com/bdp95/7dot1voiced/ and get the test WAV files.
    Use them for WAV playback. If you want AC3 or other versions, just convert to those from the WAV sources - I would suggest LameXP as a simple, straightforward GUI. That would covert most formats except DTS. For that one you can try dcaenc, surcode dts, ffmpeg or others.
    Apr 2014
    ardabil, iran
    tnx, that was good
    Apr 2014
    ardabil, iran
    lamexp can not convert multichannel audio correctly, it missed channel 4
    i downloaded ffmpeg-20141223-git-32c836c-win64-static, is it a correct release?
    how do i convert with that?
