Hello to everyone, i have a question. How can i get a short information about a videofile like this:
I know that programs like MPC, VLC and others can show information about videos, but its too long, like here:Format : AVI at 1 989 Kbps
Length : 1,52 GiB for 1h 49min 8s 800ms
Video #0 : MPEG-4 Visual at 1 533 Kbps
Aspect : 720 x 400 (1.800) at 25.000 fps
Audio #0 : AC-3 at 448 Kbps
Infos : 6 Channels, 48,0 KHz
Thanks in advanceGeneral
Complete name : G:\geforcereview.avi
Format : AVI
File size : 1.52 GiB
Duration : 1h 49mn
Overall bit rate : 1 989 Kbps
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1h 49mn
Bit rate : 1 533 Kbps
Width : 720 pixels
Height : 400 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.213
Stream size : 1.17 GiB (77%)
Writing library : XviD 1.2.1 (UTC 2008-12-04)
Audio
Format : AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Codec ID : 2000
Duration : 1h 49mn
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 350 MiB (23%)
Alignment : Aligned on interleaves
Interleave, duration : 64 ms (1.60 video frames)
Interleave, preload duration : 192 ms
