  1. Hi. when i import a Blu-ray mkv file in ripbot (1.18.1), this error appears :
    MKV Mediainfo:
    General
    Unique ID                                : 222865866462087627838380154964499107853 (0xA7AA67928FF6E925A5D5B2662CCA100D)
    Complete name                            : C:\BluRay.1080i.AC3.VC1.REMUX.mkv
    Format                                   : Matroska
    Format version                           : Version 2
    File size                                : 12.9 GiB
    Duration                                 : 58mn 47s
    Overall bit rate                         : 31.5 Mbps
    Encoded date                             : UTC 2011-05-18 04:58:12
    Writing application                      : mkvmerge v4.6.0 ('Still Crazy After All These Years') built on Mar 10 2011 02:50:32
    Writing library                          : libebml v1.2.0 + libmatroska v1.1.0
    Video
    Format                                   : VC-1
    Format profile                           : Advanced@L3
    Codec ID                                 : V_MS/VFW/FOURCC / WVC1
    Codec ID/Hint                            : Microsoft
    Duration                                 : 58mn 47s
    Bit rate                                 : 30.4 Mbps
    Width                                    : 1 920 pixels
    Height                                   : 1 080 pixels
    Frame rate mode                          : Constant
    Frame rate                               : 25.000 fps
    Scan type                                : Interlaced
    Scan order                               : Top Field First
    Bits/(Pixel*Frame)                       : 0.587
    Stream size                              : 12.5 GiB (97%)
    Default                                  : Yes
    Forced                                   : No
    Audio
    Format                                   : AC-3
    Format/Info                              : Audio Coding 3
    Mode extension                           : CM (complete main)
    Format settings, Endianness              : Big
    Codec ID                                 : A_AC3
    Duration                                 : 58mn 47s
    Bit rate mode                            : Constant
    Bit rate                                 : 448 Kbps
    Channel positions                        : Front: L R
    Sampling rate                            : 48.0 KHz
    Bit depth                                : 16 bits
    Stream size                              : 188 MiB (1%)
    Default                                  : Yes
    Forced                                   : No
  2. DECEASED
    Jun 2009
    Heaven
    MKV Mediainfo:
    General
    Complete name                            : C:\torent\BBC Madagascar 2011.BluRay.1080i.AC3.VC1.REMUX.mkv
    Please read the forum rules again:
    https://forum.videohelp.com/threads/72386-Forum-rules-Acceptable-Use-Policy-(AUP)
    Sep 2012
    Australia
    -------------------- I n T 3 r L a C e D v C 1 -----------------------
