hello
That video card recommended to use Adobe Premiere Pro CC Avid Media Composer 2014 and 8 ('ll use both programs)
with an AMD FX8350 and 8GB RAM
(not Quadro).
thank you
Anything over a GTX 760 would be overkill.
I would be more worried about 8GB, investing in 16GB probably will give you more bang for the buck. -
Google "Avid Version Matrix" to see which cards are recommended for your version. Some folks get AMD to work, much safer to go with intel. Don't play seriously with Avid with anything less than an i7. More RAM is better. Quadro is recommended, though GTX is fine if you aren't using any external hardware for ingest or monitoring. Do not fool around with Avid, stay close to the specs. Premiere is much more forgiving.
