Hello, I bought 2 HDMI cables (no name brands) from amazon. I have 2 Sony TVs, one is newer and one is much older, both are LCD TVs. My laptop can be outputted using one of the HDMI cables to both TVs. However, with the other HDMI cable, my laptop can only be outputted to the older Sony LCD. The newer Sony LCD won't read it. Is this normal? Even when I try to change the Function F8 on my laptop, it doesnt seem to read it. The other one just auto connects. Are all HDMI cables not the same?
Results 1 to 30 of 37
Just sounds like a borderline cable. It would probably work if you forced a lower resolution.
Return it for exchange as defective, assuming you don't have to pay for the shipping back. -
Yes, ALL HDMI cables are not the same. And, newer TVs have different settings (1080p or better native vs. 720p vs. 768p, etc.).
You get what you pay for.
Scott -
No, it is a probably not different settings. There could be a tiny physical difference in the connections on the two TVs and the connectors on the cable. Sometimes just turning the cable around and using the opposite end can provide better connection.
[Edit] Within reason, you get what you pay for. I wouldn't buy an HDMI cable from a dollar store. However a 6-foot $5 HDMI cable can work just as well as a 6-foot $100 HDMI cable, as long as they are both certified. Build quality and the size of the wires matters more with longer length cables.Last edited by usually_quiet; 5th Dec 2014 at 00:55.
The old TV is a Sony XBR3 that works with the amazon $5 hdmi cable.
The newer TV is a Sony KDL 70 that does not work with the cable.
Both are 1080p TVs.Last edited by jyeh74; 23rd Apr 2015 at 13:33.
always buy your HDMI cables from monoprice... I too have the Sony KDL 70 and never had a cable problem when using their
quality cables -
All I can tell you is that I've got four of the Amazon branded HDMI cables going right now and I've never had a problem with any of them to my Vizio TV.
Others in the past have recommended monoprice but I've never bought from them. That means I have no personal experience with their stuff, not that I am against them. -
The thing about monoprice is that you can be sure you're getting good cables at a very good price. Their standard high-speed rated HDMI cables are 24 gauge with quality connectors (and ferrite cores too if that matters). You can get good cables at Amazon or elsewhere, sure, but they sell some stuff that looks iffy as well.
I suspect usually_quiet is right and the problem is the connectors.Pull! Bang! Darn! -
My big brother (he's in his 70's) bought a $60.00 hdmi cable 'cause the (commissioned) salesman told him the ends were 'gold plated'. He wondered why all his friends laughed at him.
I just bought one at Frys on sale for $1.58, works fine.
-c-Yes, no, maybe, I don't know, Can you repeat the question? -
Not quite true.
At a fundamental level, all digital connections are really analog connections and so will degrade just as standard analog connections do. However, it is the error-correction in the code that should detect & correct the errors to give you a pristine digital signal at output.
Since there is degradation, there is a point at which error-correction does not work, and at that point you will get bad output. However, there are times with digital cabling & equipment where the "cutoff" is not a single steep cliff, but a jagged bluff. This is due to many factors, but the result is: the digital signal works-doesn't-works-doesn't-works, etc., sometimes within the same KB or Byte being sent. And since there is a window of opportunity for the source to resend, it's possible for that window to get missed for some of the live signals, so there are "MIDDLE" areas where it partly but not fully works.
Some of the main factors that influence this susceptibility in cable are: length of cable, braiding quality (resistance to EMI/RFI and avoidance of kinks/breaks), and connection solidity (strong solder points, conductive electrical material).
So there is still a strong correlation between manufacturing quality/cost & reliability/quality, even in digital stuff. It's just no longer an obvious choice.
The good thing is: for digital, most COMMON cabling (at appropriate lengths) is quite good enough in most situations.
Scott -
Their "Commercial Series" HDMI cable product lines include the lengths you want and use either 24AWG or 22AWG wires. Redmere cables are thinner but they are directional (one end is designated for the source and one end is designated for the destination) and include electronics that draw power from the cable to provided amplification. The electronics can fail, so it's better to use heavier cables with no electronics instead, if possible.
With respect to Monoprice, it is just a label folks not a quality standard!
Everybody can do it, you make up a name, register it, get a nice logo and do some marketing and make cool wrapping. Then buy generic cables from China and stick on your label, do the markup and voila you got a brand!
Generic cables, Monoprice or not, seems to work just fine, it is no (longer) rocket science.
The only time I would recommend no compromise cables is for live capture and cabling behind the walls.
You neglected to mention HDMI cables also need to pass certification testing to guarantee the cable is compliant. Not all cheap HDMI cables are certified, although almost any HDMI cable works up to about 10 feet, certified or not. As far as I can tell, Monoprice's HDMI cables are all certified.
HDMI cables that use 28AW, are good up to about 15 feet. Past 15 feet, heavier gauge wires, 24AWG or 22AWG, are used to reduce signal attenuation. After about 45-60 feet, even cables using heavier gauge wire will probably not pass certification.
Redmere cables and some others have built-in amplification so that thin wires can be used for longer cables and still pass certification. -
I know an inspector sits down and inspects every single cable by hand before it goes out the factory!
HDMI is licensed, that means that for each copy a cut goes to "the syndicate". I am sure "the syndicate" sends out a man once a year to take a look if things are OK, right between a big lunch and a dinner obviously accompanied with the best Wǔliángyè.
You are trolling again I see.
Of course the design is certified rather than each individual cable, and the manufacturer merely submits samples for testing. The quality of each cable is determined by the level of quality control at the factory. Monoprice wouldn't stay in business very long if many of their cables were defective, so I presume they have a way of dealing with a supplier that sends them many defective cables. -
I've got three of these "Super Slim" cables in 10 ft and 6 ft varieties. They look similar to the nGear "34AWG OD4.2MM" so I assume they use the same gauge. One of them is borderline when I connect my WDTV directly to my Samsung HDTV; random cuts to black, sparklies, etc. But the same cable connected with my AVR in the middle works with no issue.
I searched online and found these Redmere cables you are referring to. Monoprice suggested them too.
Ultra Slim 18Gpbs Active High Speed - $24.40
http://www.monoprice.com/Product?p_id=10767&rep=joe
How are they different than these? I am only using 15 ft for connecting laptop to tv, for music and movies and youtube and browsing net.
Select Series -$5.79
http://www.monoprice.com/Product?c_id=102&cp_id=10240&cs_id=1024009&p_id=2529&seq=1&format=2
Select Metallic - $7.99
http://www.monoprice.com/Product?c_id=102&cp_id=10250&cs_id=1025502&p_id=9305&seq=1&format=2
Select Active Series High Performance - $13.99
http://www.monoprice.com/Product?c_id=102&cp_id=10255&cs_id=1025507&p_id=9169&seq=1&format=2
Ultra Slim Series High Performance - $21.42 (probably because they are thinner but how are they different from the first one)
http://www.monoprice.com/Product?c_id=102&cp_id=10255&cs_id=1025503&p_id=9891&seq=1&format=2
Then they have their Commerical series, like these two but I dont know the difference.
http://www.monoprice.com/Product?c_id=102&cp_id=10240&cs_id=1024004&p_id=3663&seq=1&format=2
http://www.monoprice.com/Product?c_id=102&cp_id=10240&cs_id=1024012&p_id=4160&seq=1&format=2 -
usually_quiet
So does it mean the 36AWG wires are no good at 15ft? Like these two Monoprice is recommending? I think they might be overkill. I don't even have a 4k TV
http://www.monoprice.com/Product?c_id=102&cp_id=10255&cs_id=1025508&p_id=10767&seq=1&format=2
http://www.monoprice.com/Product?c_id=102&cp_id=10255&cs_id=1025503&p_id=9891&seq=1&format=2 -
Look at the supported resolutions. The two least expensive cables are only recommended for 1080i or 720p, maximum. If your laptop is connected to a 1080p TV and the laptop can output 1080p video, you should get a cable that supports 1080p.
The Commercial series cables and the less expensive Redmere cables are rated for 1080p. The most expensive Redmere cable is rated for 4K, although that may be moot since HDMI as we know it today might not end up as the connection of choice for 4K. Those would all work for 1080p.
The Commercial series cables are very stiff and heavy, so they aren't very practical for anything other than a permanent connection. You would probably find the thinner Redmere cables are easier to manage with a laptop. However, recall that they have to be connected correctly. The source end has to be connected to the laptop, and the destination end must be connected to the TV.
The 36AWG cables need amplification. Redmere technology provides that. Yes, the 4K rated cables are unnecessary.Last edited by usually_quiet; 21st Apr 2015 at 14:19.
You are correct. It states that some of the "active" wires are considered directional so you do have to connect the source to the laptop and the destination to the TV. I wonder why they do this? What are "active" wires? It's easier when they are not directional so either end goes to either end and you don't have to check all the time.
Some have higher Gbps transfers like the 10Gbps data throughout vs 18Gbps data throughput. Does that matter for internet browsing or playing movies off the computer?
Is 36AWG too small for 15 ft? I recall you saying that HDMI cables up to 15ft should use 28AWG. Does 36AWG lose any signals, etc? -
The amplification circuitry in the connectors is what makes them directional. Amplification is normally applied at the source.
10Gbps data throughout should be sufficient.
At 15 ft, 28AWG cables benefit from amplification, and 36AWG cables need amplification. Redmere technology provides that.
I would go with either one of these:
[Edit] Please realize that it is possible for the connector on the TV or the laptop to be a little bit off spec, or become damaged through use, and to be a source of problems, not just the connectors on cables. If that is the case, you may continue to have problems with most cables.Select Active Series High Performance - $13.99
http://www.monoprice.com/Product?c_id=102&cp_id=10255&cs_id=1025503&p_id=9891&seq=1&format=2Last edited by usually_quiet; 21st Apr 2015 at 19:54.
$21.42 for a 15ft HDMI cable?
For those who are not fooled by Monster there is always Monoprice to pick up the slack!
Jeez! -
