Results 1 to 9 of 9
  1. hi, can someone please tell me step by step how to run rtmpdump and download this video at 720p 3500k
    I have never used rtmpdump so need step by step guide
    http://www.spike.com/episodes/w6r3nj/impact-wrestling-hdimp947a-season-9-ep-947
    thank you
  2. Member Emeritus
    May 2014
    newest version of youtube-dl will do it automatically without rtmpdump, but it downloads all of the parts separately.
  3. Hi ,
    Thanks for this newest version .
    youtube-dl -U
    Updating to version 2014.12.04.2 ...
    Waiting for file handle to be closed ...
    Updated youtube-dl to version 2014.12.04.2.
    The newest version destroy the older one (2014.12.1.0) ; Why ?
    Note : The older way for updating was a good way .
    **** other QUESTION ****
    Here below one try . The file .flv is lagging .
    youtube-dl http://pluzz.francetv.fr/videos/questions_au_gouvernement_,113257137.html -o Senat-info-113257137.flv
    [pluzz.francetv.fr] questions_au_gouvernement_,113257137: Downloading webpage
    [pluzz.francetv.fr] 113257137: Downloading video JSON
    [pluzz.francetv.fr] 113257137: Downloading f4m manifest token
    [pluzz.francetv.fr] 113257137: Downloading m3u8 information
    [download] Downloading f4m manifest
    [download] Destination: Senat-info-113257137.flv
    [download] 100% of 62.48MiB in 03:02
    I have been obliged to do :
    ffmpeg -i "Senat-info-113257137.flv" -vcodec copy -acodec copy -f mp4 Senat-info-113257137.mp4
    Could it be done directly ?
    Regards .
  4. Originally Posted by ponens View Post
    can you tell me how to use it?
    how do I download the video as 720p
    if it downloads in parts will they be .mp4 files?
    if not could you tell me how to download the video with rtmpdump
    thank you
  5. Member Emeritus
    May 2014
    Download youtube-dl.exe, open windows command prompt in the folder where youtube-dl.exe exists and type:
    youtube-dl "http://www.spike.com/episodes/w6r3nj/impact-wrestling-hdimp947a-season-9-ep-947"
  6. Hi ,
    Witch formats are able in a video ?
    youtube-dl -F https://www.youtube.com/watch?v=vxdHMHuTxUQ
    RESULT
    [youtube] vxdHMHuTxUQ: Downloading webpage
    [youtube] vxdHMHuTxUQ: Extracting video information
    [youtube] vxdHMHuTxUQ: Downloading DASH manifest
    [info] Available formats for vxdHMHuTxUQ:
    format code extension resolution  note
    139         m4a       audio only  DASH audio   48k , audio@ 48k (22050Hz), 1.27MiB (worst)
    140         m4a       audio only  DASH audio  128k , audio@128k (44100Hz), 3.39MiB
    171         webm      audio only  DASH audio  143k , audio@128k (44100Hz), 3.57MiB
    172         webm      audio only  DASH audio  198k , audio@256k (44100Hz), 4.89MiB
    141         m4a       audio only  DASH audio  255k , audio@256k (44100Hz), 6.80MiB
    278         webm      256x144     DASH video   92k , webm container, VP9, 1fps, video only, 1.39MiB
    160         mp4       256x144     DASH video  124k , 15fps, video only, 2.82MiB
    242         webm      426x240     DASH video  114k , 1fps, video only, 2.35MiB
    133         mp4       426x240     DASH video  278k , 30fps, video only, 6.71MiB
    243         webm      640x360     DASH video  218k , 1fps, video only, 4.52MiB
    134         mp4       640x360     DASH video  266k , 30fps, video only, 6.16MiB
    244         webm      852x480     DASH video  395k , 1fps, video only, 8.03MiB
    135         mp4       852x480     DASH video  581k , 30fps, video only, 13.42MiB
    247         webm      1278x720    DASH video  793k , 1fps, video only, 14.59MiB
    136         mp4       1278x720    DASH video 1284k , 30fps, video only, 27.77MiB
    17          3gp       176x144
    36          3gp       320x240
    5           flv       400x240
    43          webm      640x360
    18          mp4       640x360
    22          mp4       1280x720    (best)
    If you want a specific assembly . Example = 'Format 136' + 'Format 141'
    youtube-dl -f 136+141 https://www.youtube.com/watch?v=vxdHMHuTxUQ -o Zorba.mp4
    [youtube] Confirming age
    [youtube] vxdHMHuTxUQ: Downloading video info webpage
    [download] Destination: Zorba.f136.mp4
    [download] 100% of 27.77MiB in 01:12
    [download] Destination: Zorba.f141.mp4
    [download] 100% of 6.80MiB in 00:17
    [ffmpeg] Merging formats into "Zorba.mp4"
    Regards .
  7. Originally Posted by ponens View Post
    If you're running windows, just download youtube-dl.exe. Run it at a windows command prompt, followed by the url placed within quotes.
    The above command will.
    yes
    rtmpdump is much more difficult, you have to get all the parameters manually for each and every part which is much more work. The downloads will be in .flv container.
    Did you even try youtube-dl? It is easier than falling on a log.
    OK, thanks I will try it tonight
  9. Hi ,
    Thanks to 'sysanin' .
    !!! Get the good rtmpdump file !!!
    Create a batch file ( 1 stream )
    @echo on
    rtmpdump -r "rtmpe://cp22372.edgefcs.net/ondemand/mtvnorigin/gsp.alias/mediabus/spike.com/2014/08/20/09/05/679141/HDIMP947A_clip1_1280x720_3500_h32.mp4" -o "season-9-ep-947-1.flv"
    pause
    :fin
    Here below the process :
    RTMPDump vx.y GIT-.....
    (c) 2010 Andrej Stepanchuk, Howard Chu, The Flvstreamer Team; license: GPL
    Connecting ...
    WARNING: HandShake: Type mismatch: client sent 6, server answered 10
    INFO: Connected...
    Starting download at: 0.000 kB
    INFO: Metadata:
    INFO:   duration              618.11
    INFO:   moovPosition          32.00
    INFO:   width                 1280.00
    INFO:   height                720.00
    INFO:   videocodecid          avc1
    INFO:   audiocodecid          mp4a
    INFO:   avcprofile            100.00
    INFO:   avclevel              32.00
    INFO:   aacaot                2.00
    INFO:   videoframerate        29.97
    INFO:   audiosamplerate       24000.00
    INFO:   audiochannels         2.00
    INFO: trackinfo:
    INFO:   length                18521000.00
    INFO:   timescale             29970.00
    INFO:   language              eng
    INFO: sampledescription:
    INFO:   sampletype            avc1
    INFO:   length                14834688.00
    INFO:   timescale             24000.00
    INFO:   language              eng
    INFO:   sampletype            mp4a
    264379.354 kB / 618.07 sec (99.9%)
    Download complete
    Cheers .
