Hello,
do you know what the minimum and maximum values are for the pix_th parameter of the ffmpeg's blackdetect filter ?
Thanks !
pixel_black_th, pix_th
The documentation says :
Code:pixel_black_th, pix_th Set the threshold for considering a pixel "black". The threshold expresses the maximum pixel luminance value for which a pixel is considered "black". The provided value is scaled according to the following equation: absolute_threshold = luminance_minimum_value + pixel_black_th * luminance_range_size luminance_range_size and luminance_minimum_value depend on the input video format, the range is [0-255] for YUV full-range formats and [16-235] for YUV non full-range formats.
Results 1 to 1 of 1
