To convert Divx to SVCD I set the bit rate to fully utilise the space on 2 or 3 discs. To split this file I have tried using BBMPEG with the max file setting to 800MB (after demultiplexing with TMPGENC). This splits the film into the correct size. The first file is OK but subsequent files have audio sync problems. Is there a setting I need to change?
Results 1 to 1 of 1
Cutting MKV
By thunderokami in forum EditingReplies: 2Last Post: 9th Jun 2011, 09:18 -
BBMPEG Multiplexer Question
By Krelmaneck in forum Newbie / General discussionsReplies: 16Last Post: 22nd Apr 2011, 23:59 -
[FR] Cutting TS Help Me Please
By KERNEL32 in forum EditingReplies: 5Last Post: 26th Feb 2010, 13:38 -
bbmpeg xp patch , page not found
By rabbit_hgc in forum EditingReplies: 8Last Post: 15th Jul 2009, 05:45 -
Cutting Out
By OG24 in forum Newbie / General discussionsReplies: 2Last Post: 12th Aug 2007, 18:55
