Results 1 to 22 of 22
  1. Hi guys... I have a problem with site which streaming online Tv... it use mp2t format. When i try to get link with download helper i see many files with different names like 123513523.mp2t 123513524.mp2t and so on. Can i transfer somehow the stream to desktop video player like VLC, Potplayer, Progdvb or any other?
    Do you have an example stream?
  3. http://195.154.108.35/hlstvstream/discovery/6633.ts This one of many similar links which i see when i try to copy url via download helper.
  4. So, no one knows how to capture this stream?
    Here's another example
    http://play.mrt.com.mk/play/50537/22-01-2015?options%5Bcurrent_component_instance%5D=v...5D%5Bpage%5D=1
    Download helper and similar programs give tiny mp2t files.
    My niece plays here and I need to archive this.
    [EDIT] I'm currently trying StreamTransport and it seems to work. It downloads a .mpg file which seems fine.
    Warning though, videohelp description does state that this software includes adware hence I've installed it on a virtual machine.
  5. Originally Posted by [ss]vegeta View Post
    livestreamer hls://http://stream6-prod.spectar.tv:1935/vod_8452284ed6226f4/_definst_/amlst:dm/hls/video_id/50537/token/814be262f6f4559541fb57306b140d4c/chunklist_w447767354_b844000.m3u8 best -o video.ts
  6. Member WazaKrash's Avatar
    Jan 2015
    in Europe
    Hello prince Vegeta x)
    With streaming video recorder, I can download an mpeg-2 file too.
    If with streamtransport you can have a valid video file, it's fine. For me, if the format bothers me, I use a conversion software and I convert the mpeg-2 file into mp4 (I don't know why I prefer mp4 all the time)
  7. Hi [ss]vegeta ,
    The process below is written because the token can change !!!
    In Firefox
    _ clean the cache
    _ launch
    http://play.mrt.com.mk/play/50537/22-01-2015?options%5Bcurrent_component_instance%5D=video_list&options%5Bvideo_list%5D%5Bfilter_request%5D%5Bvideo_slug%5D=50541%2F&options%5Bvideo_list%5D%5Bfilter_request%5D%5Bposition%5D=8&options%5Bvideo_list%5D%5Bfilter_request%5D%5Bpage%5D=1
    _ After 10s stop the video
    _ open an other instance for FF
    _ enter about:cache
    _ In the new page , under 'disk' click on 'List Cache Entries'
    _ in the new page search for playlist.m3u8
    select the link , copy it
    _ open a text editor , do paste , you'll get something like
    about:cache-entry?storage=disk&context=&eid=&uri=
    http://stream6-prod.spectar.tv:1935/vod_8452284ed6226f4/_definst_/amlst:dm/hls/video_id/50537/token/ca1c3b670992777e3f133ef2af435f1e/playlist.m3u8
    select and copy only http...playlist.m3u8
    _ paste http...playlist.m3u8
    _ launch it
    _ open ( or save ) with a text editor
    you'll see
    #EXTM3U
    #EXT-X-VERSION:3
    #EXT-X-STREAM-INF:BANDWIDTH=844000
    chunklist_w87227041_b844000.m3u8
    NOW you can compose the final link
    http://stream6-prod.spectar.tv:1935/vod_8452284ed6226f4/_definst_/amlst:dm/hls/video_id/50537/token/ca1c3b670992777e3f133ef2af435f1e/chunklist_w87227041_b844000.m3u8
    Cheers .
    JE SUIS CHARLIE !!!
  8. Originally Posted by biezom View Post
    What is that, where do I paste, how you got to that link?
    [EDIT] I google'd and found out about the program livestreamer, not really hefty with command line applications but I think I managed to get my hands around the .ts file, thanks. It seems like there were really a couple of ways of getting streams, which is always nice.
    Do you mean Apowersoft Streaming Video Recorder?
    I'll give it a try, thanks.
    Originally Posted by aazerty View Post
    Hi [ss]vegeta ,
    In Firefox
    _ clean the cache
    _ launch
    _ enter about:cache
    _ launch it
    you'll see
    #EXTM3U
    #EXT-X-VERSION:3
    Cheers .
    Thank you but I followed all steps, and the last link just gives me a 1kb m3u8 file to download, don't know what to do with that?
  9. Originally Posted by [ss]vegeta View Post
    Hi [ss]vegeta ,
    In Firefox
    _ clean the cache
    _ launch
    _ enter about:cache
    _ launch it
    you'll see
    #EXTM3U
    #EXT-X-VERSION:3
    Cheers .
    livestreamer hls://http://stream6-prod.spectar.tv:1935/vod_8452284ed6226f4/_definst_/amlst:dm/hls/video_id/50537/token/...................................................m3u8 best -o video.ts
    you change the red part with your result
  10. Member WazaKrash's Avatar
    Jan 2015
    in Europe
    Yep, it's that but there is a little problem, with the trial version, the software download only an extract of the video : (
    Like I said if streamtransport help you, it's fine : )
  11. Hi ,
    Don't use streamtransport , not secure !!!
    Cheers .
    JE SUIS CHARLIE !!!
  12. Guys i have, a success with the method that was explained by aazerty thx dude... In firefox chache i find this url http://195.154.72.60/hlstvstream/btvaction/index.m3u8?hash=b0AoW0btPLUoAs8tgjFypg when i paste it to pot player the video starts but after 10 -20 seconds stops. Maybe i need to use livestreamer but i need just little more help with creating the correct command. I try with this:
    livestreamer hls://http://195.154.72.60/hlstvstream/btvaction/index.m3u8?hash=b0AoW0btPLUoAs8tgjFypg best -o video.ts
    but nothing happen? The player doesn't even start.
  13. Originally Posted by Stormrage View Post
    if you use "-o video.ts" option livestreamer write stream data to video.ts instead of playing it
    if you want play directly use your command without this option
    vlc is the player by default
  14. Yep but VLC doesn't start after i run the command what's the problem?
  15. Hi Stormrage ,
    biezom has answered you previously !!!
    SIT DOWN , HAVE A DRINK , OPEN YOU EYES , READ WHAT IS SAID .
    TRY TO UNDERSTAND , IT IS NOT SO HARD TO DO !!!
    if you want play directly use your command like below
    livestreamer hls://http://...Fypg best
    INSTEAD OF PLAYING IT !!!
    livestreamer hls://http://...Fypg best -o video.ts
    Cheers .
    JE SUIS CHARLIE !!!
  16. Now open your mind and your soul and try to understand that i did it and than ask:
    I used the correct command without -o video.ts after biezom mention it...
    but the vlc doesn't start... GOT IT? If you don't know how to help don't make a stupid sarcastic posts.
  17. Hi Stormrage ,
    !!! stupid sarcastic post !!! Maybe , maybe , I have a solution but I won't give it .
    Read what you said : https://forum.videohelp.com/threads/368747-Can-i-export-mp2t-stream-to-desktop-video-pl...=1#post2375097
    ... best -o video.ts
    biezom answered you .
    After this you asked #14 : ... but VLC doesn't start after i run the command ...
    Now #16 the command is without -o video.ts
    At least the link is probably good .
    > GOT IT?
    Me , yes . And you ?
    Cheers .
    JE SUIS CHARLIE !!!
  18. Ok I'll give you my attention...
  20. Thanks .
    But "I D M" is not free !
    Cheers .
    JE SUIS CHARLIE !!!
  21. Originally Posted by Stormrage View Post
    Maybe something has changed in the past week, but the link http://195.154.72.60/hlstvstream/btvaction/index.m3u8 points to an image now instead of a text file that the .m3u8 extension would indicate.
