    Feb 2013
    Norway
    What is the difference between DGAVCDec and DGDecNV (or DGAVCDecDI)
    Do you have to have Nvidia Graphic card to use DGDecNV?
    And is DGAVCDec equal good as those 2 other programs?
  2. DGAVCDec is free, but is depreciated and no longer supported. It has problems with decoding some streams, most notably PAFF streams (e.g from AVCHD camcorders)
    DGDecNV requires a compatible Nvidia card (not all cards supported), and a license (donationware)
    DGAVCDecDI requires a license (donationware) and DiAVC license for the decoder separately ($)
    Feb 2013
    Norway
    So if I have a ATI Radeon HD 4600 graphic card, I cannot use DGDecNV but I can use DGAVCDecDI (after purchasing the Licenses that I need)?
  4. Originally Posted by brusno View Post
    Yes
    Aug 2013
    Central Germany
    You may rather try L-SMASH Works (using LwLibavVideoSource) instead.
