hi all
any idea how to rename/remove thistag in finished mpeg projects ?? is there any particular dll file in the Womble folder i need to edit/modify to solve the issue ??Code:"Writing library : (c) 1997-2005 Womble Multimedia, Inc. / MPEG Video Wizard (06/2005)"
thanks in advance
You just enter "0" (zeros) over those entries that start from "(c) Womble...". It's important to get the same number of characters exactly, or you will damage the file . If it's your first time with a hex editor, make a backup first
. That might be a reason to use restream instead if you're not comfortable with a hex editor
It will look something like this
before
after
hi poisondeathray.
HDX, editor resulted in choppy playback, reckon i must of done something wrong, have no idea what though (first time user). So i tried restream like you suggested, output was near perfect!
Bud, do you know any other nifty tool that can get the job done without demuxing the media first or even better, is there any registry patch that prevents womble from tagging media whilst encoding???
Thank You
