    Dec 2006
    Bangladesh
    Greetings..
    i am working on a DVD project on DVDLab Pro..
    but i am facing a wired issue
    please look at the attached images
    i put a button on menu on the right position but when i compile and play the dvd the button position is not same. It shows at much higher position. But if i move the mouse over the correct position mouse cursor changes to hand cursor that's mean hotspot is working but it showing the image/button at wrong position.
    how can i fix that?
    please help me out
    thanks in advance
    best regards
  2. Member DB83's Avatar
    Jul 2007
    Well unless my eyes deceive me the project appears as 16:9 but the final output is 4:3
    Dec 2006
    Bangladesh
    thanks sir, for your reply.. but that's not the reason...
    i have tried 4:3 as well but same error
    best regards
  4. DECEASED
    Jun 2009
    Heaven
    Try some of the old builds of DVD-lab PRO, then.
    Version 2.24 (assuming you can find it elsewhere) was not bug-free of course, but IMHO it sucked less than the recent ones.
    AFAIK, every release of DVD-lab has some conflicts between the Designer Module and the Compiler Module
  5. one can bypass those design-in features just importing ready menu (bmp) with subpicture (bmp)
