  1. Hello,
    I would like to encode some video files with muxed audio tracks in it but i just want the video to be encoded and keep the audio tracks as it is.
    In order to calculate the appropriate bitrate for my encoder to proceed the video file i would like to know the audio tracks file size in my source file.
    I thought it would be easy to figure it out but i can't find any tool who whould provide this basic information.
    For exemple in Media Infos i've got the bitrate of the audio track but not the actual size in Mb.
    I know that i could figure out the size by myself with the bitrate and the duration information but i'd like to know if there is a tool that provide the info directly please.
    Thanks for your tips !
  2. As with video:
    size = bitrate * running time
  3. Member Cornucopia's Avatar
    Yes, and also, for LPCM audio raw streams:
    bitrate = running time * samplerate * bitdepth * #channels
    Dec 2012
    The Palatinate
    MediaInfo will give you the size of each individual stream. Be sure to select one of the more verbose output formats.
  5. Thanks, i didn't saw that mediainfo could be more verbose, that'll do the trick !
    Cheers !
