hi everyone, i wanted to downloaded a video from YouTube using en.savefrom.net or http://www.keepvid.com/. but it seems that youtube send audio and video separately for resolutions more 720.
i so downloaded them the i could, separately.
but now i cannot mux them.
i use mkvmerge but i get error code2,Error: No streams to output were found. Aborting.
my sources are:
VIDEO:
AUDIO:Code:General Complete name : F:\... Format : dash Codec ID : dash File size : 481 MiB Duration : 3mn 52s Overall bit rate : 17.4 Mbps Encoded date : UTC 2014-02-17 23:52:00 Tagged date : UTC 2014-02-17 23:52:00 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L5.1 Format settings, CABAC : No Format settings, ReFrames : 2 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 3mn 52s Bit rate mode : Constant Bit rate : 17.4 Mbps Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Variable Frame rate : 23.976 fps Minimum frame rate : 23.974 fps Maximum frame rate : 24.291 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.087 Stream size : 481 MiB (100%) Encoded date : UTC 2014-02-17 23:52:00 Tagged date : UTC 2014-02-17 23:52:00
Code:General Complete name : F:\... Format : dash Codec ID : dash File size : 3.52 MiB Duration : 3mn 52s Overall bit rate mode : Constant Overall bit rate : 127 Kbps Encoded date : UTC 2014-02-17 23:51:12 Tagged date : UTC 2014-02-17 23:51:12 Audio ID : 1 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 3mn 52s Bit rate mode : Constant Bit rate : 126 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 44.1 KHz Compression mode : Lossy Stream size : 3.48 MiB (99%) Encoded date : UTC 2014-02-17 23:51:12 Tagged date : UTC 2014-02-17 23:51:12
I had the same error with mkvMerge so finally I used myMp4BoxGui (mp4 instead of mkv) and it worked.
Save your trouble by using ChrisPC Free VideoTube Downloader
Stopping development until someone save me from poverty or get me out of Hong Kong...
Twitter @MaverickTse -
Hi darknesslord ,
What I should do .
Regards .Code:I suppose you got : keepvid.h264 keepvid.aac I suppose the fps=24.000 Create a batch file ( ex. Z_keepvid.bat ) @echo on "MP4Box.exe" -add keepvid.h264:fps=24.000#video -add keepvid.aac#audio -new "keepvid_final.mp4" rem rem verify you got 1 file ("keepvid_final.mp4") pause :fin Put it in the directory containing "MP4Box.exe" . Launch it . -
thanks for answer
MP4box GUI worked fine, no need to trouble myselft with coding unless i am batch muxing
