    Nov 2014
    Erath
    persian and arabic texts are connected together but mencoder show them seperated one by one like
    س.ل.ا.م (without '.') instead سلام is ther any way to tell mencoder its a rtl text i am using this code:
    mencoder input.mkv -sub input.srt -subfont-text-scale 3.0 -subpos 95 -sub-bg-alpha 50 -utf8 -o encoded.avi -oac mp3lame -ovc lavc
    any reply could be helpful
    thanks
  2. DECEASED
    Jun 2009
    Heaven
    Convert the .SRT file to .SSA or .ASS (encoded in UTF-16), and then try again.
    Make sure you have an up-to-date build of Mencoder.
    If it still doesn't work, then use Avisynth + VSFilter.DLL --- both Mencoder and ffmpeg can read AVS files.
    Nov 2014
    Erath
    thanks El Heggunte problem solved.
