Hi! So I recently converted to using Shadowplay instead of Fraps, and at first everything was fantastic. Smooth and constant recording, no hiccups with editing the files. Soon after I ran into the first problem; Virtualdub threw up an error stating that "no audio decompressor could be found to decompress the source audio format," tagged 00ff. After some searching, I found a solution with using a plugin (I think it was the DirectShow plugin, or Quicktime) and the issue ceased for a day. The next day, output AVIs had screwed up audio but removing the Quicktime plugin resolved it. The next day I had to put it back in to make things work, and also updated my CCCP codec installation. This back-and-forth struggle with making things work went on for a few days culminating in things mostly working thanks to a host of plugins and the use of AudioCoder to reencode the audio from the source Shadowplay recordings to WAV. I thought everything was okay until today. Now I've got this problem where VirtualDub only loads the first minute or so of a video, but only when I have the QuickTime plugin installed. If I remove it, it loads full videos, but on at least one video the program has gotten stuck on a video frame and aborted the export, and also frequently locks up trying to dub previews.
The list of plugins I'm using:
AC364
DShowInputDriver
FFInputDriver_64
FLIC64
FLV64
Matroska64
MPEG264
QuickTime64
WMV64
If I could figure out why the Quicktime64 plugin is causing videos to only load a small portion of the whole, I'd be alright for now, but I'm completely lost as it is.
e: This is on Windows 7 Professional 64-bit.
I would get rid of the codec pack and install ffdshow instead and set it to support H264/AVC (and anything else you might need) with libavcodec. I'd install XviD and DivX 6.9.2 separately though.
I assume all your input plugins are fcchandler's. If not, make it so. Tateu's has not updated in years and the SEt MPEG-4 plugin causes problems if another MPEG-4 plugin is installed.
I would also install fcchandler's ac3acm and aacacm codecs and also the lameacm codec. (pretty much everything by fcchandler).
