Would like help to capture this 52 minute documentary. Better if using free method to capture.
http://putlocker.tw/watch-dive-online-free-putlocker-2010.html
Hi jimdagys ,
You'll have to create a batch file ( ex. Dive.bat ) , using a text editor , see below :
Install the batch file in a directory containing FFMPEG.EXE
You'll get 'Dive.mp4'Code:@echo on ffmpeg -i "https://r9---sn-25ge7nez.googlevideo.com/videoplayback?requiressl=yes&shardbypass=yes&cmbypass=yes&id=d8ca582f7afe11c2&itag=18&source=picasa&ip=109.210.97.143&ipbits=0&expire=1419022811&sparams=cmbypass,expire,id,ip,ipbits,itag,mm,ms,mv,requiressl,shardbypass,source&signature=4832B9261D5E9E0AD7B6FF3533A6CC3455E819DF.658972B7EE9431185B3526B19546AF024432F9FF&key=cms1&begin=0&cms_redirect=yes&mm=30&ms=nxu&mt=1416431218&mv=m" -c:v copy -c:a copy -f mp4 "Dive.mp4" pause :fin ==== launch it ( below the result ) ffmpeg version N-58869-gae33007 Copyright (c) 2000-2013 the FFmpeg developers built on Dec 7 2013 22:01:45 with gcc 4.8.2 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnu tls --enable-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetype --enable-libgsm --enable-libilbc --enable-libmodplug --ena ble-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger - -enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-li bvorbis --enable-libvpx --enable-libwavpack --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib libavutil 52. 56.100 / 52. 56.100 libavcodec 55. 45.100 / 55. 45.100 libavformat 55. 22.100 / 55. 22.100 libavdevice 55. 5.102 / 55. 5.102 libavfilter 3. 92.100 / 3. 92.100 libswscale 2. 5.101 / 2. 5.101 libswresample 0. 17.104 / 0. 17.104 libpostproc 52. 3.100 / 52. 3.100 Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'https://r9---sn-25ge7nez.googlevideo.com/videoplayback?requiressl=yes&shardbypass=yes&cmbypass=yes&id=d8ca582 f7afe11c2&itag=18&source=picasa&ip=109.210.97.143&ipbits=0&expire=1419022811&sparams=cmbypass,expire,id,ip,ipbits,itag,mm,ms,mv,requiressl,shardbypass ,source&signature=4832B9261D5E9E0AD7B6FF3533A6CC3455E819DF.658972B7EE9431185B3526B19546AF024432F9FF&key=cms1&begin=0&cms_redirect=yes&mm=30&ms=nxu&mt= 1416431218&mv=m': Metadata: major_brand : mp42 minor_version : 0 compatible_brands: isommp42 creation_time : 2014-08-31 09:04:24 Duration: 00:52:48.94, start: 0.000000, bitrate: 609 kb/s Stream #0:0(und): Video: h264 (Constrained Baseline) (avc1 / 0x31637661), yuv420p, 640x360 [SAR 1:1 DAR 16:9], 510 kb/s, 29.97 fps, 29.97 tbr, 30k tbn, 59.94 tbc (default) Metadata: handler_name : VideoHandler Stream #0:1(und): Audio: aac (mp4a / 0x6134706D), 44100 Hz, stereo, fltp, 96 kb/s (default) Metadata: creation_time : 2014-08-31 09:04:50 handler_name : IsoMedia File Produced by Google, 5-11-2011 Output #0, mp4, to 'Dive.mp4': Metadata: major_brand : mp42 minor_version : 0 compatible_brands: isommp42 encoder : Lavf55.22.100 Stream #0:0(und): Video: h264 ([33][0][0][0] / 0x0021), yuv420p, 640x360 [SAR 1:1 DAR 16:9], q=2-31, 510 kb/s, 29.97 fps, 30k tbn, 30k tbc (defaul t) Metadata: handler_name : VideoHandler Stream #0:1(und): Audio: aac ([64][0][0][0] / 0x0040), 44100 Hz, stereo, 96 kb/s (default) Metadata: creation_time : 2014-08-31 09:04:50 handler_name : IsoMedia File Produced by Google, 5-11-2011 Stream mapping: Stream #0:0 -> #0:0 (copy) Stream #0:1 -> #0:1 (copy) Press [q] to stop, [?] for help frame=94973 fps= 60 q=-1.0 Lsize= 237320kB time=00:52:48.94 bitrate= 613.5kbits/s video:197557kB audio:37136kB subtitle:0 global headers:0kB muxing overhead 1.119348%
!!! If not running !!! Below the process to catch the stream .
Code:Firefox => about:addons => install "User Agent Quick Switch" => right-click on the icon ( top right corner ) => write ipad => validate --- Click on the icon ( top right corner ) to enable
Code:Firefox => about:addons => install "HttpFox 0.8.14" => to make it running open firefox , do < Ctrl Shift F2 > simultaneously !!! click on 'Start' , on the left !!! LET THE PAGE OPEN !!!
Code:open another page Firefox => paste your link http://putlocker.tw/...-2010.html after the video has began , quit this firefox's session
Regards .Code:Go at the Firefox's page with "HttpFox" CLICK ON 'STOP' Look in the column 'Type' , and see a line containing 'video/mp4' Select it , and choose 'Copy row' Open a text editor , and paste the link Select 'https://r9---sn-25ge7nez.googlevideo.com/...=m' Put it in the previous batch file (above)
Thanks. Used the code that you provided:
and pasted into ffmpeg dos box and it downloaded the video ( into the bin folder of ffmpeg).Code:ffmpeg -i "https://r9---sn-25ge7nez.googlevideo.com/videoplayback?requiressl=yes&shardbypass=yes&cmbypass=yes&id=d8ca582f7afe11c2&itag=18&source=picasa&ip=109.210.97.143&ipbits=0&expire=1419022811&sparams=cmbypass,expire,id,ip,ipbits,itag,mm,ms,mv,requiressl,shardbypass,source&signature=4832B9261D5E9E0AD7B6FF3533A6CC3455E819DF.658972B7EE9431185B3526B19546AF024432F9FF&key=cms1&begin=0&cms_redirect=yes&mm=30&ms=nxu&mt=1416431218&mv=m" -c:v copy -c:a copy -f mp4 "Dive.mp4"
