It does not do it if the source is from DVDs only Blu-rays and MKVs.
I do not tell it to burn them in and make sure the forced and burn are unchecked.
I have tried both using the folder mode and file mode, either way it burns them in.
I am using VLC and there is no option to turn them off.
Use MKV as output and the PGS is muxed in the output file. For MP4 it'll hardcode. I believe MP4 can only hold VOBSUB - not PGS.
From https://trac.handbrake.fr/wiki/Subtitles
Bluray PGS Subtitles
With MP4, you can burn ONLY 1 subtitle track into the video.
With MKV, you can pass-through multiple PGS tracks. These are not burned into the video unless you choose to do so however you can only burn 1 subtitle track into the file. The rest must be passed through. -
Did you check the "Burn In" checkbox?How come mp4 can only make non burnt in subs when using a dvd source?
