Results 1 to 14 of 14
    Nov 2014
    Hi - still have much to learn & have a question.
    I recorded this with a samsung HD HMX-F90. In HD, 1280x720 @ 8274kbps & 29 frames/second (so says the file properties box).
    Does this look a bit blurry? I expected it to be clearer. I havn't done anything to this (encoding-wise) except upload it to youtube & trim it down to a few seconds.
    https://www.youtube.com/watch?v=MwXUj7WDf_s&list=UU1xLJkYsIPzxHxCt3bs24uA
    And - what's with 29 frames? Everything refers to 30 - is 29 a problem?
  2. Banned
    Oct 2014
    Northern California
    We cannot see it, the video is defined as private.
    Nov 2014
    oh! thanks. fixed that.
  4. You know, don't you, that YouTube reencodes everything at relatively low bitrates? It doesn't look like that on your computer, does it?
    Nov 2014
    yeah - I do know that, and yes - it looks pretty much the same on my computer. . .
  6. Well, this one has a bitrate average of about 2500.
    And it's 29.97fps. Sometimes it's referred to as 30fps and sometimes, but more rarely, as 29fps.
    Nov 2014
    sorry to be dumb, but what does that tell me?
  8. For one thing it tells you the YouTube version isn't anywhere near the quality of what you uploaded. As to why your source video is almost as blurry, I haven't a clue. Maybe if you made it available, too, then we could learn more.
    Nov 2014
    Oh. ok! here. I appreciate your patience!
  10. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    Looks like it was shot with a tablet, cell phone or cheap low-quality camera. Get a better camera.
    Nov 2014
    I didn't think the samsung HD HMX-F90 was a great camera, but are you saying it's total crap? I do have other files shot with it that don't look quite so bad. . .
    Is that really all there is to it? I need a better camera? But then what does HD mean in a camcorder? I thought that implied it would be sharper at the least. . .
  12. Member racer-x's Avatar
    Mar 2003
    You shot indoors with questionable lighting. Your camera compensated by applying Gain + Noise Reduction, which in turns equals Soft Image.
    You really should learn the basics of shooting, lighting and settings.
  13. Originally Posted by ccapra View Post
    It only tells you the resolution height is greater than 576. Hi-def at a low bitrate is still hi-def, even if it looks like crap. Hi-def shot using a poor quality camera is still hi-def. In short, being hi-def tells you nothing about the quality. YouTube, for example, is full of hi-def videos made from VCD sources and, as you'd expect, they look like they came from VCD. I know nothing about cameras and defer to my betters, such as racer-x.
    Nov 2014
    Ok - that helps, both racer-x & manono. I am learning. Thanks!
