Hello. Has anyone with success, by using Handbrake created a file where chapters are actually working on PS3?
Before encoding using Handbrake, I can see the chapters on the Chapter tab, and the encoded file also shows the chapters in VLC.
But when I want to see the movie on my PS3 there are no chapters. Nor on my WD TV Live
So: If You have working chapters on PS3 with a handbraked file, could You please tell me what setting You are using?
Thank you
	Well, I have tried both - m4v and mp4. In the mp4 file mediainfo look like this:
 (Chap1 and Chap2 at the bottom)
 General
 Complete name : C:\Users\Public\Videos\Title00-1-1.mp4
 Format : MPEG-4
 Format profile : Base Media / Version 2
 Codec ID : mp42
 File size : 483 MiB
 Duration : 24mn 49s
 Overall bit rate : 2 717 Kbps
 Writing application : HandBrake 6509svn 2014110901
 Video
 Format : AVC
 Format profile : Baseline@L4.0
 Format settings, CABAC : No
 Format settings, ReFrames : 1 frame
 Codec ID : avc1
 Duration : 24mn 49s
 Duration_FirstFrame : 22ms
 Bit rate : 2 549 Kbps
 Width : 720 pixels
 Height : 576 pixels
 Display aspect ratio : 16:9
 Frame rate mode : Constant
 Frame rate : 25.000 fps
 Standard : PAL
 Color space : YUV
 Chroma subsampling : 4:2:0
 Bit depth : 8 bits
 Scan type : Progressive
 Bits/(Pixel*Frame) : 0.246
 Stream size : 453 MiB (94%)
 Writing library : x264 core 142 r2479 dd79a61
 Encoding settings : cabac=0 / ref=1 / deblock=0:0:0 / analyse=0:0 / me=dia / subme=0 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=0 / keyint=250 / keyint_min=25 / scenecut=0 / intra_refresh=0 / rc_lookahead=0 / rc=crf / mbtree=0 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=20000 / vbv_bufsize=25000 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=0
 Color primaries : BT.601 PAL
 Transfer characteristics : BT.709
 Matrix coefficients : BT.601
 Color range : Limited
 Audio
 Format : AAC
 Format profile : LC
 Codec ID : 40
 Duration : 24mn 49s
 Bit rate mode : Variable
 Bit rate : 164 Kbps
 Channel(s) : 2 channels
 Sampling rate : 48.0 KHz
 Compression mode : Lossy
 Stream size : 29.1 MiB (6%)
 Title : Stereo / Stereo
 Language : Danish
 Menu
 Codec ID : text
 Duration : 24mn 49s
 Language : English
 Bit rate mode : CBR
 Duration_FirstFrame : -289477
 00:00:00.000 : chap1
 00:10:00.163 : chap2
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
