Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
  1. Member blinky88's Avatar
    Mar 2004
    Australia
    Need help .... DDR3 1066mhz, 204 or 240 pins ?????????
    Thank you in advance to members that know more than I do.
    Cheers from downunder.
  2. 2 x 204Pin SO-DIMM DDR3 1066/800
    It's not important the problem be solved, only that the blame for the mistake is assigned correctly
  3. Member blinky88's Avatar
    Mar 2004
    Australia
    Thank you, appreciated.
