Results 31 to 60 of 66
Yes indeed, I see it now.
Premiere Pro seems to fix this automatically both the fps and the weaving.
I don't understand why the video should be down sampled. -
I just burn for relatives, and day to day stuff comes right off an old SD DVD recorder. Life is hell when your relatives refuse to buy BluRay players. The good stuff goes to BD or AVCHD with menus on hard drives. The wife wants menus for long movies and the good stuff, so I pretty much stick to standard formats there.
Nice work on this one, jagabo (No surprise).
I don't either. I guess the O.P. just wants it that way.- My sister Ann's brother -
@jagabo, besides the script, what else I need to have in order to achieve what you did? Which program did you use to reduce the bitrate?
I used the x264 command line encoder, feeding the AVS script directly to it. The command line was something like:
Code:x264.exe --preset=slow --crf=21 --me=dia --subme=1 --keyint=50 --sar=1:1 --output sample.mkv sample.avs
Thanks. This is a bit technical for me, since I never used command line editors.
So, do I go to www.x264.nl and download x264.exe in order to use this?
Instead of Sample.mkv, can I also put Sample.mp4 if I wanted an MP4?
Is the audio being 'copied' as is, with this command?
Thank you for your patience. -
x264.exe doesn't "copy" audio , the regular vanilla versions don't process audio at all
Yes, if you put MP4 it would output MP4, if MP4 support has been compiled (videolan dropped MP4 container support a while back, they might have put it back in , not sure)
If you wanted a command line tool that copies audio as well, ffmpeg would be better choice
If it's easier for you, there are many GUI's available for x264 that accept avs scripts.
eg. ripbot, xvid4psp, megui, simple x264 launcher, many more.... even ffmpeg GUI's will accept avs scripts eg. winff, tencoder, ffqueue, many more.... -
Ok. Then I would just give that script as input to those GUIs, and without changing any settings in those GUI's other than the CRF value, will I get the desired out as jagabo achieved?
No, because he used custom settings that differ from the default settings or presets.
If you used the same settings, and same x264 version, then you would get the same output. So if you wanted to use exactly the same settings, you would just enter them in the GUI . I wouldn't get hung up on the x264 settings here, it's the script that is doing the important work
If you're ok with using the command line, it's probably easier to use ffmpeg IMO, because that muxes audio as well in the same step -
If you wanted to try ffmpeg, here is the same settings he posted, translated for ffmpeg, and "copy" audio from original file
All you would need to do is change "input.avs", "input.mp4" , "output.mp4" to the real names and paths , adjust the CRF value
Code:ffmpeg -i input.avs -i input.mp4 -map 0:0 -map 1:1 -c:v libx264 -preset:v slow -crf 21 -g 50 -x264opts ref=1:me=dia:subme=1:colorprim=bt709:transfer=bt709:colormatrix=bt709 -vf setsar=sar=1/1 -c:a copy output.mp4
The reason why you couldn't include audio in the avs script, is avisynth frameserves uncompressed audio & video, so "direct stream copy " wouldn't work . So ffmpeg just copies it from the original file -
Excellent, that makes it easier for me. Thanks. I will try it tonight and post the results.
It's an external plugin, ffms2.dll is required
https://github.com/FFMS/ffms2/releases -
Is that with jagabo's script or with directshowsource? Likely directshowsource is decoding it differently . Directshowsource() relies on system installed codecs and splitters. So what I get with directshowsource on a computer might be different than what jagabo ,or you, or anybody gets
If you used megui, post the avs script used, and the log file -
When you preview the script in vdub, does it look ok if you go frame by frame?
Hmmm, I actually get something jerky with jagabo's script, he probably copy/pasted it incorrectly, or his version of ffms2 is doing something different than mine
I would put SelectEven() at the end, so TFM() has access to all the fields first before any decimation operations, this seems to fix it for me (this works with DirectShowSource for me as well , with lav splitter and decoder configured)
FFVideoSource()
AssumeFPS(50)
AssumeTff()
TFM()
SelectEven()
Preview your .avs in vdub and go step by step to see if there is any jerky motion, or combing or any other issues . There is something different going on between our systems that is yielding slightly different results -
I'm using the Cplugin 2.6 version, This one specifically r936
http://forum.doom9.org/showthread.php?p=1698838#post1698838
Hmm, it's repeatable here (even with seekmode=0), it likely has to do with ffms2 or that version , because directshowsource works fine with either script
The difference (on this setup) is that version of ffms2 starts with triplicate frames (not field), so starting with selecteven() will delete the wrong frames before tfm()
I swapped out to the official 2.20 version, deleted the index first, and it still produces the same results (triplicate) . ffms2 does rely on haali media splitter for MKV, but not for MP4. So I don't know what else would explain the difference. It's almost certainly a decoding/ source filter difference (so much for "preaching" about ffms2 being more consistent, LOL )Last edited by poisondeathray; 22nd Nov 2014 at 10:05.
His "output.mp4" has a few duplicate frames (correct frames replaced by duplicates) and encoded 4:2:2 . The "chroma ghosting" is probably what he is referring to as combing. I'm guessing something in his directshow chain converted to RGB while still in fields
It doesn't matter if you delete the first of the duplicates or the second. There must be something else going on. In my final output I see only one duplicate frame at the start (you can get rid of that by using SelectOdd() instead of SelectEven()), no missing frames. I just tried the r936 version and got the same thing again.
Yes, it works ok as expected on another computer that had r936 as well
Something is very buggy on that this computer, because selecteven() or selectodd() returns the wrong frames, even with seekmode=0. I'll have to figure it out, but this shouldn't affect the OP's results, his "output.mp4" demonstrates another set of issues. -
Hi all, sorry about the delay. I downloaded the ffms2 thing from the link provided, however, it is a folder that has many subfolders. I tried copying the ffms2.dll into AviSynth's plu-ins folder and then running the script of jagabo. It gives me an error message that says 'the DLL is either not designed to run on windows or it contains an error...". I am not sure how to 'install' this DLL.
I got the fastforwarded video result with DirectShowSource. ffVideoSource never worked for me anyway, since the DLL was not installed.
Regards -
jagabo, how do I 'install that plugin? I am using all 32-bit.
I tried with DirectShow again after removing SelectEven) as you suggested. The output is still fast video (fast forwarded)...
Also, when I removed SelectEven() with DirectShowSource, the output video shows as 50 fps in MediaInfo. With SelectEven() included, the output video shows as 25 fps in MediaInfo.Last edited by nharikrishna; 23rd Nov 2014 at 00:17.
