Results 1 to 10 of 10
  1. Hi VH ,
    How do you open ffdshow ? I dont see any .exe file to open it !
    How can I open it ?
    Thank you ....
  2. Start - All Apps...see the picture :
    http://i.minus.com/ibmFj2n1Gzh61J.jpg
    May 2014
    Memphis TN, US
    Start -> All Programs -> ffdshow -> list of configuration utilities inside the ffdshow program group.
    > Oops. Beat me to it on that one. But "Apps" isn't in Windows 7.
    - My sister Ann's brother
  4. are you sure that the user "PrinceSwaraj" use Win 7 ?
    I gave the path and image it is for me to Win 10 :
    http://i.minus.com/igCEMFFQXBCn0.jpg
  5. Yes .. I am using Windows 7
  6. I think there is a comand in Run .. But I cant find that thread now ....
  7. Member DB83's Avatar
    Jul 2007
    Well I thought that when it is installed (and appears in your program list) it is invoked (runs) as and when it is required (no over-riding codec or filter used).
    As above, you can access the various encoder/decoder options by selecting them from the program list.
  8. Can anyone tell me Command to be entered in Run ?
  9. DECEASED
    Jun 2009
    Heaven
    Path-To\rundll32.exe Path-To\ffdshow.ax,configure
    Path-To\rundll32.exe Path-To\ffdshow.ax,configureAudio
    Path-To\rundll32.exe Path-To\ffdshow.ax,configureVFW
    Path-To\rundll32.exe Path-To\ffdshow.ax,configureRaw
    Path-To\rundll32.exe Path-To\ffdshow.ax,configureAudioRaw
    Path-To\rundll32.exe Path-To\ffdshow.ax,configureSubtitles
  10. Member DB83's Avatar
    Jul 2007
    Read this:
    http://obinshah.wordpress.com/2011/05/08/list-of-all-installed-codecs-on-your-windows/
    especially follow the part about Windows Media Player. If ffdshow is running it will appear on the information screen under video codecs etc. when you follow those instructions.
