  1. Smaller frame size video plays fine in Media Player that comes with the Flash card system I use but when the video is re-encoded to larger frame size (640x480) it shows a grey screen with just a few color artifacts at the top of the screen. Sound still plays OK.
    When I use the current version of MPlayer to play the same video, no problem.
    Is there a setting that I can use to make MPlayer not do the "grey screen" on the larger frame size?
    I would like a work-a-round till the author of the Flash card system upgrades to the latest MPlayer.
    Thanks!
    Bob
  2. If this is related to your other thread, the older mplayer binaries cannot handle decoding yuv444p (aka YUV 4:4:4), only yuv420p (aka YUV 4:2:0) .
    So you would have to encode your videos with yuv420p
    Can you just drop in a new binary into your program? (maybe rename it?)
  3. How do I get to see those choices using something like Video to Video to convert? I like that one because it is simple (albeit too simple if I can't control this feature of encoding ) and has batch capability.
  4. If there is an extra commandline box in that GUI for ffmpeg , you need to enter "-pix_fmt yuv420p" (without the quotes)
    Or use some other ffmpeg GUI. Tencoder can batch convert a folder and has access to commanline. I think winff can too
    Or it's pretty simple to write a dos batch file for ffmpeg
  5. The FFMPEG job that created the initial video that has the culprit 4:4:4 used this parameter to encode... -vcodec libx264 -vf
    What would -vcodec would be be better to use... is there one that would be readily playable on Windows, Mac and Androids but still be 264 quality... and not produce the 4:4:4 problem?
  6. The FFMPEG job that created the initial video that has the culprit 4:4:4 used this parameter to encode... -vcodec libx264
    What -vcodec would be better to use... is there one that would be readily playable on Windows, Mac and Androids but still have 264 quality... and not produce the 4:4:4 problem?
  7. you want to use -vcodec libx264, but with -pix_fmt yuv420p
  8. It worked great, Thanks!!
    I plugged it in on the extra params line on Video to Video and it produced the 4:2:0.
    Thanks a million!
    Bob
