apologies for being new to converting, but I have converted successfully in the past and have searched for an answer in the Forums and help sections, but to no avail. Basically I have converted a copy of 'A Beautiful Mind' (AVI) to SVCD using Tmpge. Picture quality is real crisp after conversion, but sound is zero, zilch, nothing...... Have tried playing in Media Player and WinDVD with the result of pic but no sound. ANY ideas or help would be welcomed very muchly! :D
there are a couple of ways you can try to fix it. One way is to open the original avi in virtual dub--set the audio to Full Processing mode, then go to "file" and choose "save wav." Then with the resulting wav file, you can use something like db poweramp to convert it to mp2 (with the appropriate codec--their link is in the tools section here at VCD Help). Then remultiplex it with TMPGenc. The audio should be fine after that (God willing). Sometimes TMPGenc doesn't do so well encoding the audio/video from the same source.
3d video with dts sound how to convert to ac3 sound
By fredddiemercury in forum Video ConversionReplies: 4Last Post: 2nd Nov 2011, 14:54 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 14:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 11:58 -
AVI - sound with VLC , no sound Toast burned
By BattyRoy in forum MacReplies: 15Last Post: 27th Jul 2007, 20:21 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 18:01
