If I use the following ffmpeg command to split a DV-AVI file will the output be a lossy or lossless copy?
ThanksCode:ffmpeg -i input.avi -vcodec copy -acodec copy -ss 00:00:00 -t 00:30:00 output.avi
Lossless copy of the video. You might have to enter other commands, stream mapping to get all the audio streams depending on the type of DV
Poisondeathray to the rescue!
What other commands do you think I might need? Here is the mediainfo for the AVI, iow, this is 720x480i29.97 NTSC DV with PCM 48/16 stereo audio. Thanks!
Code:General Complete name : D:\Video\Library\Tape22.1.avi Format : AVI Format/Info : Audio Video Interleave Commercial name : DV Format profile : OpenDML File size : 13.7 GiB Duration : 1h 4mn Overall bit rate mode : Constant Overall bit rate : 30.3 Mbps Video ID : 0 Format : DV Codec ID : dvsd Codec ID/Hint : Sony Duration : 1h 4mn Bit rate mode : Constant Bit rate : 24.4 Mbps Encoded bit rate : 28.8 Mbps Width : 720 pixels Height : 480 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 29.970 fps Standard : NTSC Color space : YUV Chroma subsampling : 4:1:1 Bit depth : 8 bits Scan type : Interlaced Scan order : Bottom Field First Compression mode : Lossy Bits/(Pixel*Frame) : 2.357 Time code of first frame : 00:00:26;20 Time code source : Subcode time code Stream size : 13.0 GiB (95%) Audio ID : 1 Format : PCM Format settings, Endianness : Little Format settings, Sign : Signed Codec ID : 1 Duration : 1h 4mn Bit rate mode : Constant Bit rate : 1 536 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Bit depth : 16 bits Stream size : 708 MiB (5%) Alignment : Aligned on interleaves Interleave, duration : 968 ms (29.00 video frames)
