Hello, dear all.
Just for curiosity, I'm testing a program to make a backup of a whole dvd movie that belongs to me.
The program tested is DVD2one. Previously I had tested another program: DVD Shrink, with good results.
What sparked my curiosity is that using DVD Shrink resulted in a perfect backup, no picture or sound problems.
But, when using DVD2one resulted video with problems concerning "interlaced" images.
How to fix that using DVD2one? how to proceed? Is that possible using such program?
I found a thread that says something about the subject.
---> Http://forum.doom9.org/showthread.php?t=45121
If the solution is like as indicated in the above thread:
"All that is needed is to demux the video and remove the pulldown flags, yielding 23.976 progressive video".
How to do this then? Which programs to use?
Remembering: I wanna make a backup of the whote DVD, with all existing menus and extras.
Just follow the information about the material that I have with me:
Format : MPEG-PS
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : Variable
Bit rate mode : Variable
Bit rate : 4 507 Kbps
Maximum bit rate : 8 000 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.435
Time code of first frame : 00:59:59:00
Time code source : Group of pictures header
Stream size : 625 MiB (89%)
Audio #1
ID : 189 (0xBD)-128 (0x80)
Format : AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Muxing mode : DVD-Video
Bit rate mode : Constant
Bit rate : 224 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 31.1 MiB (4%)
Audio #2
ID : 189 (0xBD)-129 (0x81)
Format : AC-3
Bit rate : 224 Kbps
Thanks for advices!
Best regards.
devil (johner)
You said you're making a backup - another DVD. So you shouldn't have to remove the interlacing. However, why use the inferior DVD2One when DVDShrink is the better program? When played on the TV (not necessarily a software player), the player or television should do the deinterlacing for you. Did you burn it to disc and play it in a DVD player already?
As for removing the pulldown, I believe AvsToDVD can do that for you. Also, it's a way better program than either DVD2One or DVDShrink. -
Hello, manono!
You are right in saying that DVDShrink is better than DVD2One. However, I do not know why, when I used DVDShrink does not properly processed the dvd which I tried to back up. It gets larger than would fit on one 4.7 GB disc. I try change some settings on the program, but did not work!
After that I tried using DVD2One to see if the problem would be solved: backing up the complete DVD, including menus and extras. Using that program I could compress everything to one disc, but the image remains with artifacts "interlaced video".
Furthermore, I would be able to test a 100% portable program which you can use anywhere I go, without having any other type of supplemental program installed. The advantage is that both DVDShrink and DVD2One can be found like this: portable.
Do you know any other program that does the conversion from DVD to DVD and it is 100% portable, similar to DVDShrink, without any need to install any other program to run it?
I guess that AVStoDVD is a better program, but we need to install some other things to make the program works properly, like AviSynth. It's not a 100% portable program.
Not yet. I will do that as a test and verify if the image still goes interlaced or not.Did you burn it to disc and play it in a DVD player already?
Sadly, on a PC, using VLC as a dvd player, the image/video goes interlaced from my DVD2One's backed-up dvd.
Thanks for the tips!
Best regards.
devil (johner)Last edited by devilcoelhodog; 8th Nov 2014 at 09:04.
Hehe, nope, sorry. I don't use any of those all-in-one programs but do it all manually using many different programs. Maybe someone else can help.
But, unless the video gets resized somewhere along the line (it shouldn't) or unless it gets transcoded as progressive (that's not supposed to happen, but I've heard of some programs doing it), no player should have any trouble telling when a DVD should be deinterlaced. Maybe you can check the DVD2One version in MediaInfo or GSpot to see if it was transcoded as progressive, rather than as interlaced.
