hi guys i need urgent help with converting to this format
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 247 MiB
Duration : 24mn 17s
Overall bit rate : 1 423 Kbps
anyone here know a program to get me this format,format profile and codec ID
i have been searching but couldn't find anything
mp42 is the old non-standard Microsoft MPEG 4 Part 2 encoder. If you install that codec you should be able to encode with it with VirtualDub.
http://fourcc.org/mp42/ -
Actually if that info is from mediainfo, that just refers to the container. It's MP4 container muxed with mp42 format profile (base media v2). There are slightly different specs and variations for MP4 container
e.g If I take a random Youtube video
Code:Format : MPEG-4 Format profile : Base Media / Version 2 Codec ID : mp42 File size : 375 MiB Duration : 46mn 46s Overall bit rate mode : Variable Overall bit rate : 1 120 Kbps Encoded date : UTC 2014-10-09 22:21:00 Tagged date : UTC 2014-10-09 22:21:00 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.1 . . .
You need to show the rest of the report, about the video compression
But for the container you can use various mp4 muxers, like mp4box, lsmash. Even ffmbc, ffmpeg can be set to mux in this fashion -
Sorry. I saw "need... mp42" and jumped to conclusions.
And if you explain the reasons behind the "urgency" or some background info it might help as well. There might other considerations about the video, audio and/or container you might need to adjust
