  1. I cant afford PS so could someone do that and post a 1280x720 template of the scanlines? I can do the rest myself with Virtualdub.
    I want to add a CRT/arcade type style to my video and this seems like the best way to do it.
  2. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    Gimp and Paint.NET are two good free image editors, use those.................
    .......Or do your dumb effect in Aviutl, at least you'll have more adjustments.
  3. If you just want to fill every other scan line with black you can do it all in VirtualDub:
    What you can't see is that the Fill filter fills half the frame with black.
  4. Wow that was easy, very nice program )
  5. The Demo video wrongly refer that effect to "Scanline". Scanline should be something like what jagabo presented.
    And, the pattern simulation in PS is not quite right IMO.
    I have made several similar effects with AviUtl and encoded the GIFs here for comparison:
    (around 60MB of GIF data, would take a while to load!)
    I have attached the AviUtl project file(zipped) for your reference (original video not included)
    Stopping development until someone save me from poverty or get me out of Hong Kong...
    Twitter @MaverickTse
  6. Member Skiller's Avatar
    Oct 2013
    Germany
    crt_display AviSynth plugin is much more realistic than just filling every other line with black. It has proper aperture and phosphors emulation.
