First of all, my DVD plays mp3s and i already tested playing movies (mpeg) in it and it worked. Now, what im asking is, Can i make 1 cd that will play both mp3s and mpeg movies? If so, how? can i do it with EasyCD Creator 5?
Doesnt anybody know? c'mon, its not that hard of a question. someone must know this. plz help.
If its not that hard of a question, you might be able to find the answer by using the search function on this site -- This question has been asked an answered several times before.
There are two ways to approach making the disc you want to make:
The first is a straight data-only CD. If you have a forgiving player, like an Apex (or, a Daewoo as I do), you can mix and match MPEG video files and MP3 files onto a data disc and pop it in your player. Video and audio will play if its an MPEG, and audio will play if its an MP3.
The second is a properly formatted VCD (or XVCD), with MP3 files on it. Your DVD player will only recognize the VCD tracks and ignore the MP3 files, but the MP3 files are still playable in your computer or on a portable CD-based MP3 player.
The approach that will work best in direct answer to your question is option one. -
The first answer is the one im looking for. I hope it works, thx!
If anybody has any other suggestion, you are more than welcomed to write in here. Thx in advanced
Can you play XVCD?
If you can, you can encode an mp3 and for video, use a jpeg and set the video bitrate as low as you can.
Can't play MP3s on my Sony DVP NS355 DVD player
By harrylentil in forum DVD & Blu-ray PlayersReplies: 4Last Post: 6th Aug 2009, 15:04 -
How can I get my DVD to play the disks I make?
By LloydE in forum Newbie / General discussionsReplies: 13Last Post: 13th Jun 2009, 18:37 -
Windows Movie Maker: AVI's sound bad, MPEGs won't play
By Canopus Smoker in forum Newbie / General discussionsReplies: 3Last Post: 26th Nov 2008, 11:54 -
Make volume same for several MP3s
By vjdnld in forum AudioReplies: 9Last Post: 1st May 2008, 10:39 -
why do mpegs play with green flashing lines obscuing the picture??
By cyberraga in forum Software PlayingReplies: 1Last Post: 13th Dec 2007, 15:57
