Results 1 to 10 of 10
  1. Im trying to achieve an RPG dialog style box for a video. I have a video file which contains the box with a nice animation that appears and dissapears. Now I just need to put the text on top, appearing on the classic RPG fashion, example:
    How could I make the text appear typewrited like that? I only own Camtasia, I don't have enough money to afford After Effects or Vegas. Do I really need these to create this simple effect?
    Oh btw, when I mean transparent, I dont mean that the box has to be transparent, I mean that I just want the white letters appearing under a transparent background, I don't know if you get what I mean. For example, take this:
    http://wigflip.com/minifesto/
    If I could get this but instead of a black background, transparent so I can add it on top of my dialogue box on my video, I would speed it up a bit and that would be it. It's a pretty shitty workaround tho, because when you scale it it gets a bit blurry since the original size is so small.
    Anyway, what ideas you have to do what i need? thanks.
  2. Those aren't "real" typewritter effects in the YT video, because whole words - or several - are revealed at once. But I get the general idea of what you're trying to do
    It's possible with free software like AVIUTL, using a mask reveal; or another approach is to use subtitles e.g. aegisub . Just google "aegisub typewritter effect" there should be many tutorials
  3. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    Aviutl can do that typewriter text effect and it is a free video/effects editor.
  4. Originally Posted by racer-x View Post
    hi, can you explain how is it done? I cant find the option to do it.
  5. Member racer-x's Avatar
    Mar 2003
    Watch my 1st tutorial on basic editing. https://forum.videohelp.com/threads/360967-AviUtl-video-tutorial?p=2288628#post2288628
    Basically you just need to adjust "vDisplay" in the text properties. You can set the speed you want.
  6. Thanks, will try later.
  7. Member Cornucopia's Avatar
    BluffTitler. Easy. Output can have alpha, too.
  8. Originally Posted by racer-x View Post
    I got it working nicely. But, i've noticed on the letters Aviutl is somewhat making everything seem a bit smooth and it isn't as sharp looking as in camtasia for some reason. Why is this? I have no filters applied afaik.
  9. Originally Posted by rocco123 View Post
    Does this refer to white text on black backgound (or vice versa) ? or colored ?
    If you refer to colored text, then it's probably because of chroma subsampling 4:2:0 . You would need to encode in RGB, or YUV444
    http://en.wikipedia.org/wiki/Chroma_subsampling
  10. It is possible with AviUtl to make "(chuncky) typewriter" effect without mask.
    The key is using the inline tags like
    <w0.1> :wait 0.1s
    <w*0.1> : wait for (no. of char*0.1)s
    <c0.1> : clear text after 0.1s
    The smoothing, or anti-alias, can be switched off in the [Detail] button at the right edge of the Text Object dialog box.
    This zip file is the AviUtl project file that generate the above GIF.
    Stopping development until someone save me from poverty or get me out of Hong Kong...
    Twitter @MaverickTse
