I'm looking for a tool that allows me to edit idx/sub files and save them in the same format.
The subs are part of a 720p bluray rip. The problem is half of the subs of the episodes have a transparent background, and half of them have a black background.
I would like to edit the files so all subs have a transparent background.
I can open the sub file in Subtitle Edit and turn on the transparency, but the problem is I can't save it in the same format. When I chose to save it as a .sub file (there are several, I tried DVD format) the subs don't load anymore.
Is there a way to save this type in Subtitle Edit, or is there another tool that can edit transparency on these files?
	You can use Subtitle Edit and import to bring in, OCR and edit and then export to IDX/SUB again.
	install subtitle edit or use the portable version. Use file import sub/idx and it will load the subs. Convert by ocr'ing. Edit it main page and choose export to sub/idx vob subs.
	aha! I completely missed the export and only tried the save as...
 thanks for explaining
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
