  1. Hi!
    I have problem with one CGA2VGA converter - problem is only in colors, saturation and brightnes and all color values.
    I own AG Neovo X-22 LCD which allows me these changes:
    brightness, contrast, backlight settings:
    colour settings:
    image settings:
    and this makes from this output (default)
    this result:
    So, you can see the BIG difference.
    Exist any software which allows so big color changes incl. capturing video, images and sound?
    I know AmaRecTV - always crashes with my PEXHDCAP...
    Please give me any advice.
    Thank you for all.
    Miro
  2. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    I don't do video capturing, but I would imagine ffmpeg should be able to do that, read the docs. I can't help you though.......
    Maybe Virtualdub with some filters applied like Gradation Curves?
  3. Hi!
    Thank you very much, but I'm not able to use video tool by command line... in video I'm newbie.
    In case of VirtualDub I found not yet so precise color manipulating
    Miro
