i downloaded a video off youtube and i dunno why the uploader had the video rotated 90 degrees left.... is there a way to save the mp4 with the right rotation?
Results 1 to 13 of 13
does someone know if format factory can rotate a video 90 degrees while keeping the aspect ratio and the quality (nearly the same)?
Never used format factory, but what you want to do will require crop/zoom functions and will need to be re-encoded.
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
thanks a lot! having problems with Mindows Live Movie Maker:
- file is 210 mb 720x540px
- looks like that
- its properties
- new file settings
- and exported is 1 GB !!!
- and looks like that
1. the scaling seems to be 1:1 ?
2, can i have a less big file but without (or not much) loss?
thanks mates -
Sorry for the late reply, quite busy at the moment.
I updated XMedia Recode to the latest version and tried it for you.
Open all files you want to convert, mark one, adjust settings for rotation (add filter now), add to joblist and same for next files. Then Encode
Should work like here
Klaus from Bavaria -
Do not convert the framerate to another one. It will stutter or similar motion artifacts will occour while playing.
Open the files with MediaInfo or MediaInfo Lite or you just look at informations of the opened files in XMedia Recode.
Set it to custom and you can use almost every codec in any container format.
language setting is available in options/preferences/language -> You don't have to use the authors my and native language.
Resolution should be kept that means the old width is the new height because we rotate the video files or you add black bars to get 16:9
It depends of the selected codec if it supports that special resolution
Hope this helps you
