  1. Hi all. Trying CCE for the firdt time but not having much success. Says the avi is not an ECL for cinemacraft. Anyone know what this is and what I can do? Also, what settings do you suggest to make dvd's?
    Thanks. [/b]
  2. That should be in the CCE manual.
    As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
  3. Checked the manual and could not find any reference. That is why I am stumped. But thanks for the response.
  4. I use CCE 2.50 patched
    and resize by avisynth
    to convert divx to 480x480 SVCD
    CCE is so fast and better image than TMEGEnc.
    Feb 2001
    Berlin, Germany
    Read the manual carefully. Of course it is explained how to use the encoder. Drag and drop the source file into the window. ECL is a Encoder Control list, aka project file.
