i am trying my first encode with this and it is producing vaf and ecl files, whats going on? what did i do wrong?
i followed the tutorial (maybe not properly) and i haven't a clue!![]()
i cannot find a guide for total newbies and really want to get this to work before i even thnk about getting it.
thanks a lot
vaf is the video information file, that is necessary for VBR multipass encoding. ecl is a project file. Have a look at the cce manual and search the forum.
I am trying to encode an avi using CCE sp and get a messge that I need to use an ecl file. Have you found out what that is yet? I cannot find anything in the manual either.
Just drag and drop the source file into the cce window. If you select file > open, you can open a project file only. Of cource you can write the project (.ecl) yourself, but that might be quite heavy stuff at the beginning.
http://www.doom9.org/mpg/cce_guide.htm
From the WTF? Files
By Soopafresh in forum Off topicReplies: 7Last Post: 19th Apr 2009, 16:46 -
wtf is it?
By zoobie in forum Off topicReplies: 10Last Post: 25th Dec 2008, 17:03 -
Some DVD authoring programs will not accept CCE encoded mpeg2 files
By ettin in forum Authoring (DVD)Replies: 8Last Post: 18th Jun 2008, 15:57 -
Problem DVD Rebuilder Pro: Is not a ECL for CCE SP Trial Version
By Talayero in forum DVD RippingReplies: 2Last Post: 30th May 2008, 14:25 -
CCE mpv files imported into NeroVision are half as long???
By binister in forum Authoring (DVD)Replies: 7Last Post: 26th Feb 2008, 16:04
