Results 1 to 9 of 9
  1. Hello member,
    I am new here.
    i want know that how can i record screen like this video.
    can suggest me how this is done.
    here is video link
    https://www.youtube.com/watch?v=UaEhvGeFK3M&list=UUDOw0nGzWsHQ9jL2vHviMgw&index=5
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Just in case you are spamming, I gave that video a Thumbs DOWN.
  3. Am not spamming.
    i want know how this video is created. which software is use to make such video.
  4. Member Cornucopia's Avatar
    I'm pretty sure that screen wasn't recorded, but was rather created in an NLE with stock FX loops & stuff.
    I guess it could have been done in PowerPoint or similar, with similar stock FX loops. Then it's output is either converted or sent out via vidcard->separatePC->capturecard, or via videoscreencap (if the PC is hefty enough).
    Either way, the stock FX loops are trite & mundane & overused, even if they're somewhat pleasant-looking. After the intro, the rest is one of the worst snoozefests! Bad layout & formatting, bad color combinations, no coordination, or movement. NOT GOOD. You do NOT want to emulate this. Even skipping/skimming, I couldn't watch more than 15 seconds of this.
  5. Ok. I want know that if i want create such video with help so screen capturing than how can i make it. He use ppt in video.
  6. Banned
    Oct 2014
    Northern California
    You could use Fraps, Camstudio or if you run a CUDA card Shadowplay.
  7. What are you asking exactly ? Powerpoint has options to export video directly
    Are you asking about the overlay of the man (the video of his face) ? or about the writing ? or just the simple slides ?
    What context is this in? Are you trying to produce a video for a lecture ?
    Why are you asking about screen capture? What screen are you capturing ?
  8. is ppt is converted into video. i think it recorded with screen capture. am not sure abt it.
    i want make same style video. i want to use slide and face and writing also..
    want make video lecture..
  9. Originally Posted by newpball View Post
    it create to big size video.
    i want my face should be visible in video like i video link i have posted above.
