Hi ****
please consider I have a mp4 file that have duration of 1 minute
but I would like trim it so that is have to encoded from 0 to 0:00:31.040000
can use time instead of frames?
I'm in a 25fps timebase, thanks
Results 1 to 10 of 10
I assume that is H:M:S.ms notation ?
You have to convert to frames. Obviously you cannot trim video on fraction of a frame
1/25 = 0.04
31 * 25 = 775
775+1 = 776 frames -
but I need use avisynth
please racer do you know is exist a batch that automatically convert the value:
00:00:31.04
or
0:00:31.040000
or
00:00:31.040
or
00:00:31,040 (etc.. but is the same time value)
into -------------> frame count @ 25 fps?
thank you -
use a calculator..................
31.04 x 25 = 776
Avisinth:
trim(0,775)Last edited by racer-x; 31st Oct 2014 at 14:16.
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
Then script it with string parsing, saved to temporary memory values and then process & combine them. There are scores of excel code on the web for doing just this, and you should be able to port the ideas to a batch file, right?
Scott -
Well, then I wouldn't worry about it: cats have no need for timecode.
