Results 1 to 25 of 25
    Oct 2014
    greece
    hello guys.nice to meet u .i didnt fix my control panel yet because i am 24 hours try to fix my video.i capture a video with my android smartphone and someone who didnt like what i capure modified my video to extension 3gpp.tmp.tell me how can i find what coecs missing so i can play it again.or to convert it to another file?please is so important for me and my eyes get out trying fix it.
    media info \Desktop\pithanonvideo.3gp
    Format : MPEG-4
    Format profile : 3GPP Media Release 4
    Codec ID : 3gp4
    File size : 80.4 MiB
    other info is....
    file name-pithanonvideo . 3gp
    file format-unknown file format
    file size on disk-84,326,809 bytes 80,420 mb
    data size-84,192,289 bytes 80,387 mb
    video stream ----codec type RAW RGB ( )
    CANsomeone help me....this video shows i am inicent and no guilting...(sorry for my english.
    it was erased and i recovery back.
    thank u very much
    i appriciate ny help or not
  2. If I understand you right, you see a file on your desktop named pithanonvideo.3gpp.tmp? All you have to do is to change the file name to pithanonvideo.3gp
    If you only see pithanonvideo.3gpp, just remove the extra P at the end. If you're positive there should be a .tmp at the end, you will have to go to Control Panel - Folder Options and remove the check mark from "hide extension of known file types", then you will be able to see all the extensions and change them.
    Oct 2014
    greece
    hi thank u very much for reply.i did already this.because i google them snd told me so.the problem is sais some codecs misssing.this videois to proove i am not guilding.i am inicent and try to trap me.thats why is very important to me.i can send it to someone to fix it and send it back but is this safe?or they will appear the video before the court and then i will have doubleproblems?
    Oct 2014
    greece
    i just did the hide extensionand i willtll u in a couple of hours what happened.thank u very mych my friend.i appriciate this .i really appriciate this
    Oct 2014
    greece
    with bs player sais this.............BS.Player cannot play the media file.
    You don't have necessary codec installed, file may damaged or not media file.
    Click 'Find codec' to try to find codec.
    Oct 2014
    greece
    another messaga of gom player is this..............
    There are a number of possible reasons why the codec you require could not be located:
    The file you are attempting to play / convert may not be an audio or video file.
    The file you are attempting to play / convert may corrupted/damaged.
    The codec you require may not be freeware/shareware, and therefore we cannot provide you with a download link or additional information.
    Our database may simply not be able to determine which codec you need based on the information it received.
  7. Originally Posted by victim View Post
    You said the file was deleted and you recovered it, recovering a file is never guaranteed to work, it's possible your file was only partially recovered. Try playing it with VLC. Also, post the mediainfo details in tree mode.
    Oct 2014
    greece
    i try vlc and nothinghappen.media info details in tree mode is what?sorry for beeing not expert in electronics but i dont know how to find the details u want to post?can u tell me please?...thanks for reply
  9. In Mediainfo click on View and select tree.
    Oct 2014
    greece
    ok.i didnt realise mediainfo is a programm.so i downloade and did what u said.i edit vieo clic view then click tree and sais this
    c;users/myname/desktop/vid_20141017_000914.3gp
    general
    complete name;c;users/myname/desktop/vid_20141017_000914.3gp
    format mpeg-4
    format profile;3gpp media realese 4
    codec id;3gp4
    file size 78.4 mb
    bu the way2 files recover.the one is this the other is pithanovideo but it sais excactly the same things in media info except the time is the name and the mb is 80.4 mb.same things.only name and size change.thank u very much for ue help my friend.appriciate
    Oct 2014
    greece
    i am sure i can recovery the video because i had threads if the video shows up i will haveproblems.so the hacker who did this knows that the video can play again.if they were sure about the video is not playing again .whu to say those things to me.the other day i went for a few beers in a cafe-bar and i open my pc to google some staff i want to see.2 of them came next table and trying to watch what i am doing to the pc.they follow mw.i must fix it and give it to my cousins and my family if something happeened to me to upload the video straight away.
    Oct 2014
    greece
    general
    format mpeg-4
    codec id;3gp4
    file size 78.4 mb
    the first post sais the other file info.same.only name and mb changes.name is the one i gave after i recover it..
  13. When you view a file in tree view with mediainfo you should see something that looks like this, notice the extra details about Video and Audio after General. What I'm interested in is the duration of the video, the bitrate, CODEC and resolution. An 80 MB video is either low res, low bitrate or really short. Anything else and that would mean you have an incomplete recovery.
    Oct 2014
    greece
    so....there is two things..or ididnt use the mediainfo correct or i didnt recover the file..probably the second.i didnt recover full file.is there any way to recover it?...i want to thank u very very much u reply to all my questions and help me to solve my big problem.i will trynow to recovery it with asoftech data recovery,this programm is not free i pay 39 dollars or35 omething euros.if not with this programm do u have any suggetions?
    Oct 2014
    greece
    i edit a norml video and i c in tree the same picture as u sent.so imust find a way to full recover the video.
    Oct 2014
    greece
    do u need amy other info so i can find a software to recover the data i want.the video?i capture it from my android 4.1.1smartphone..any other ino u need?please nic2k4?
    Oct 2014
    greece
    maybe we find something .i run adr and found 2 files dbf but what makes me believe is that is the same mb .the 80.4 and the oter 78-9 i cant remember.but i believe is that.dbf file?what the hell is that again?i am not computer specialist.sorry for too many posts but it is extra emergency,nic2k4 i really thank very very very very much for ur help
  18. Member
    Oct 2014
    greece
    no any other reply?coz of the pm?
  19. Sorry mate, haven't seen the PM, yesterday was October 31st; party time. Try Recuva, if the file you want to recover has red dot next to it, it's gone and there's nothing you can do. If it's yellow, it's partially overwritten, but there's a small chance that some of it is playable. In both cases it doesn't bode well.
    Was this video recorded by a security camera (cctv)? If it was you might need a specific player to view the video. All the cctv DVR's I've seen will include the player with the footage when the video is exported. You need that player.
    Oct 2014
    greece
    dont worry about the pm...thanks for all replies u did to me to helpme.i will try the software u tell me but theother videosi ecoverhad a yelow triangle.no red spot.but i see some other videos not recordind.downloadedviedow to have this triangle and wasok.they were playing.the video capture frommobile android smartphone 4.1.FFROM MOBILE ANDROID.whatdo u thik about videos capture from android?is it easy to recovery them?THANK U VERY VERY VERY MUCH!!!!!!!!!
    Oct 2014
    greece
    if it was cctv videotheywouldnt understand i had this video.but thanks for all.i will try tomorrow the recuva cozi am very b usy right now and i will reply back what happened
  22. Member
    Oct 2014
    greece
    i found it both files.it is yellow spot.sais bad cituation.and sais also This file is overridden with E/DCIM/DCIM/Camera/VID_20130926_135644.3GP"""
    THE OTHER FILE THE SAME BUT CANGE THE 20131102_135106.3gp""
    so what do u think?ibelieve itvcan be recovery.and play?people like u r expet in pc;s and now with this info i believe u understand what they did to my video.i will wait for u reply anytime u can.thanks a lot
  23. Member
    Oct 2014
    greece
    hiagain i upload here this video.if someone can ffix it some innocent people will not go to jail.this video shows cops to put drugs someones pocket to excuse the police brutallity they use...bad cops.the kid 15 years old is still in jail after 4 days in coma....please someone help.with this video i use it in public probably i will go to jail too because they told not to use it.buut i cant stay calm when i saw unfair things.thanks to everyone who try to help me especially nic4........my e-mail is irakliotaki@hotmail.gr
    http://www.megafileupload.com/en/file/577575/VID-20141017-000914-3gp-tmp.html
  24. Member
    Oct 2014
    greece
    guys i found what happened...the video wasnt this...they left the name to confuse me...i try it with a software tool repair and didint work...when i was eady to leave it i decide to tryit with another video it was same megabit...quess what?it works but i had only 3 minutes....so now i figure out what they did...the trick they did not tofind the video probably with ur knowledge i can make it play....nick ask me for tree of media info..one minute to upload thefoto....
Name:	Στιγμιότυπο οθόνης (53).png
  25. Member
    Oct 2014
    greece
    after i use the software tofix it mgbit ws less and appears the medi info..i just change he nam...
