Hi!
I own Startech PCI Express HD Capture Card known also as PEXHDCAP.
On CD in package are drivers and Stream Catcher software. I'm using also Movavi Video Suite, but only Stream Catcher allows to work with device settings.
I need to turn off deinterlacing and software allows to select only between mode High, Medium and Low.
So:
Is possible to turn off deinterlacing of PEXHDCAP? Or if, is possible to work with advanced device settings?
Thank you for every help, reply or comments.
Miro
	Did you ever try using AmaRecTV to see if you could access the desired settings? Note that I do not have a PEXHDCAP, so I cannot confirm how well AmaRecTV works with it, only that it is supposed to work with it. http://www.videogameperfection.com/2012/07/30/startech-pexhdcap-capture-card-tutorial-...ture-software/
	I know AmaRecTV and was user of.
 AmaRecTv is near impossible to configure to work with PEXHDCAP (in my case always shows error message).
 I was user of it before owning PEXHDCAP, it works correctly with USB grabbers, my TV Card works not with, at least webcam yes.
 Alternative which works with all devices is Movavi, I'm user of it, but it allows to change common video settings like brightness, contrast, color, TV system etc.
 Really works with device config only Stream Catcher - problem is that I don't know manufacturer and searching web for homepage is useless 'cause it shows all streaming programs to use with network stream...
 If exist newer version of it I can't to download it
 I can try only Startech support page for any configurer, but nothing new...
 Miro
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
