I downloaded a couple of dvd rips wich are encoaded in divx form...my question is should I encode them as vcd or svcd I was wondering If I would see a visual difference?![]()
The way I understand it is, the SVCD standard uses mpeg2 encoding which makes for better quality picture than VCD, but there are few stand-alone home DVD players that will play SVCDs. If you're wanting to burn and watch movies on your tv, then you should probably go with the VCD standard unless you test your DVD player with an SVCD and find that it will play it.
if vertical resolution is above 240 then go with svcd to preserve the max picture detail
DVD Decrypter rips where DVDFab can't
By audax in forum DVD RippingReplies: 2Last Post: 3rd Jan 2010, 20:27 -
Converting rips to large .avi files
By HartsVideo in forum Video Streaming DownloadingReplies: 2Last Post: 24th Jul 2009, 23:32 -
Clearest DVD Rips
By dudeman316 in forum DVD RippingReplies: 38Last Post: 18th May 2009, 09:33 -
Converting HD-DVD Rips to MP4 Without Quality Loss
By mpalm887 in forum DVD RippingReplies: 1Last Post: 10th Jan 2008, 12:14 -
DVD RIPS (non copyrighted) for educational use...
By Spooky_uk in forum Newbie / General discussionsReplies: 3Last Post: 30th May 2007, 19:33
